Project Fi interchiller
Old Jun 20, 2024 | 03:04 PM
GaiaXF-V8S's Avatar
Those dimensions would probably be between 1 and 1.5 gal. I wanted to try to get at least a 2 gal in, but if you are able to fit something there I may choose to do what you have done here. My plan was to convert the air intake to a larger single pipe and put the reservoir in place of the removed airbox. That comes with its own challenges, but can be done. Are you going to foam insulate the reservoir?
Old Jun 20, 2024 | 03:21 PM
Gasman2's Avatar
I am going to ask fi
As that's the return going into the reservoir I don't think it should be insulated.
The route is reservoir to pump. To chiller to supercharger then return back to reservoir
Old Jun 25, 2024 | 02:58 PM
Gasman2's Avatar
Sligh change of plan
Reservoir was too big and bulky
So am fitting one of these which will feed a second one a sealed one with a an10 male to go to the pump and a an10 male at top
That will be a total of around 4l
Found a slot for the pump just waiting on the tanks to be made
Old Jul 8, 2024 | 10:56 PM
Gasman2's Avatar
My tanks should be arriving today
In terms of mistakes made that have cost me time
The barbed fittings I wasted time and money trying to braze them
Just get them tig welded it's quick and cheap
The suction line hose you have to tee into is likely to kink so I have cut a 90deg piece of ali pipe and sleeved and welded it
To make things easier take your front wheel and arch liner out
I also got a joiner for the liquid line with the pressure sensor welded in as the sensor needs to be before the solenoid
Relay for the pump have mounted in the small fuse box at front of car
Take the trigger from the original pump for the trigger and pull power from the yellow wire in the fuse box and fuse with 30amp to term 30 and out on 87
I have modded my lines with all new ptfe braided hose and joined with silicon at the chargecooler
Old Jul 8, 2024 | 11:11 PM
Gasman2's Avatar
2x y piece an10 for flow and return to chargecooler centrally mounted for equal flow rates
Mount pump relay in here...I have used a fused relay
Suction line fitting
Suction line elbow to avoid kink in hose
Liquid line fitting
Splice joiner with sensor to be mounted before the solenoid
Old Jul 9, 2024 | 09:28 AM
GaiaXF-V8S's Avatar
Great progress! I always knew that splicing the AC lines would be one of the more difficult parts of this project. Looks like you found some good solutions. Interested to see the tank system you have in mind. What's the plan for the supercharger coolant lines at the supercharger? I was looking to have them converted to accept AN fittings.
Old Jul 9, 2024 | 11:05 AM
Gasman2's Avatar
Tried an fittings it's too tight I have adapted the originals
Old Jul 13, 2024 | 10:55 AM
  #28
Gasman2's Avatar
Just had a bit of a reshuffle and moved pump over to nearside
It looks a bit messy in there but is not actually visible when the bumper is on
Tbh you could hook up to the original flow and return lines but I have used 90 braided pipe and the stock lines were in a hideous position and must have heat soaked badly
Now everything is routed I just have to hook up the header tank with a an4 feed line
Old Jul 13, 2024 | 01:32 PM
GaiaXF-V8S's Avatar
Great work!
Old Jul 16, 2024 | 10:24 PM
  #30
Gasman2's Avatar
Had a bit of a tidy up
All water lines now redone in 90% stainless and rerouted from original location so less heat soak to the lines
Soon as I have time will finish off the air con lines
Old Jul 22, 2024 | 11:16 PM
  #31
Gasman2's Avatar
Fitted the new viezu cold air induction kit as fitted to their predator 2
created some much needed space and figment is spot on
Old Jul 30, 2024 | 04:14 PM
  #32
Gasman2's Avatar
Right it’s all in and regassed
these are the temps in my garage with no airflow through the 2 condensers and engine fans off which I need to get altered to permanently on
Ambient air temp 27deg Celsius Manifold air temp 29deg Celsius Remember this is stationary and no airflow through the 2 condensers
Reservoir on right and all necessary hoses insulated to avoid condensation and temperature loss
Old Aug 17, 2024 | 04:44 PM
  #33
GaiaXF-V8S's Avatar
Anymore updates on this project?
Old Aug 24, 2024 | 05:10 PM
  #34
Gasman2's Avatar
Now I have completed the install
this is my reservoir of chargecooler circuit
yes that really is Ice
now this mode is only really for you quarter mile or traffic light warriors
Old Aug 24, 2024 | 06:31 PM
  #35
GaiaXF-V8S's Avatar
That's amazing! What IAT2 temperatures are you seeing now compared to ambient?
Old Aug 25, 2024 | 03:10 PM
  #36
Gasman2's Avatar
Iat2 is a couple of degrees above ambient but that’s stationary with no airflow
but that water is bloody cold
Old Aug 26, 2024 | 10:45 PM
  #37
GaiaXF-V8S's Avatar
How does the car feel power wise? Do you see lower than ambient temperatures when driving? I'm dying to get this installed on my XF as well as VAP dual pulley and tune.
Old Aug 27, 2024 | 12:03 AM
  #38
Gasman2's Avatar
I have a mapping session booked for next week
Old Sep 28, 2024 | 01:55 PM
  #39
GaiaXF-V8S's Avatar
Any update on the project?
Old Sep 30, 2024 | 09:18 PM
  #40
Gasman2's Avatar
Yes
all up and running
averaging 2 deg above ambient without using water meth
