Radiator Cap
Old Jun 14, 2022 | 08:39 AM
cpq100's Avatar
Default Radiator Cap
I was checking the coolant level last night and got a surprise. Embossed on the bottom of the radiator cap was "FoMoCo". That would be the company with the blue oval logo and not the one with the growler.
I bought the car new so it had to come from the factory with that cap installed.
Old Jun 14, 2022 | 11:41 AM
scm's Avatar
scm
The engine was originally designed when Jaguar was under Ford ownershp so it made sense to use a few Ford standard bits. Your water pump will also be stamped FoMoCo (might explain why they fail so much?).
Old Jun 14, 2022 | 07:36 PM
OzXFR's Avatar
Starting in 2009 for the V8 up until 2020 the AJ133 V8 and AJ126 V6 were built at the Ford Bridgend engine plant in Wales.
JLR then shifted production to their big new plant in Wolverhampton.
At the Bridgend plant the engines were built in a separate area under an agreement with Ford and it made sense to use a lot of Ford parts but even then these were long block parts not short block parts.
Because of this and the fact that it is a 90 degree 5 litre V8 with quad overhead cams and four valves per cylinder, lots of people including motoring journalists who should know better assume the AJ133 is a Ford engine and a derivative of the Ford Coyote 5.0. No it is not, it is a completely different engine designed from the start by JLR with as far as I know zero common components with the Coyote other than maybe one or two peripheral/ancillary bits.
I don't know if JLR still uses Ford made parts stamped FoMoCo on the V8 but I'm guessing they do.
Edit - I just checked my coolant expansion tank cap and yes it has FoMoCo on the underside, but it also has "made in India", go figure!
Old Jun 15, 2022 | 04:38 AM
scm's Avatar
scm
The original 4 litre versions of the engine (Aj26, renamed AJ-V8) were built at Bridgend from 1993. And, according to Nigel Thorley, the only parts from the Ford parts bin were a woodruff key and the sump plug. I guess he didn't consider the water pump to be part of the engine .....
Old Jun 15, 2022 | 12:38 PM
clubairth1's Avatar
Community Influencer
The water pump is made by Ford. It does not fit any Ford engine.
Old Jun 15, 2022 | 03:39 PM
Unhingd's Avatar
The oil filter housing on my V6 is a FoMoCo.
Old Sep 27, 2022 | 04:46 PM
Jose's Avatar
Made in India or China to Ford specifications.
Old Sep 27, 2022 | 08:00 PM
mcphill's Avatar
Didn't WatchJRGo show many more parts with FoMoCo? Like the camshaft holders and other internals?
Old Sep 28, 2022 | 11:25 AM
clubairth1's Avatar
Yes tons of stuff with FoMoCo on it. Has been that way for quite a while.
Old Sep 28, 2022 | 11:34 AM
scm's Avatar
scm
Since the introduction of the XK8, I suspect.
95 Cat
Oct 8, 2021 12:02 PM
alanroberts50
Apr 6, 2021 10:42 AM
Harry Peter Rose
Feb 15, 2018 05:46 PM
Muti007
Mar 17, 2015 07:46 AM
