Rhythmic whoop noise coming from rear
Old Apr 24, 2025 | 07:52 AM
SportsEngineer's Avatar
Default Rhythmic whoop noise coming from rear
I recently started hearing a noise similar to this (this video isn't from my car, just a random video I found on youtube with the closest noise to what I'm hearing in my car)
The best way I can describe it is a "rhythmic whoop". Some additional info:
1. I have a MY 2015 F-Type R RWD
2. The sound isn't present when I first start driving. It takes 5 mins or so before it starts to become noticeable.
3. The frequency of the whoop sound increases with speed
4. No codes are being thrown
I'm calling my indy mechanic today to schedule a visit. Any thoughts on what it might be?
Old Apr 24, 2025 | 07:56 AM
Obviously I think it's a bad wheel bearing, but I want to rule out a bad rear diff. (fingers crossed)
Old Apr 24, 2025 | 09:10 AM
Lothar52's Avatar
the diff always worries me. I’m careful not to abuse the car and I’ve been having diff oil changes done every 20k miles. 🤷🏻
Old Apr 24, 2025 | 10:01 AM
Valerie Stabenow's Avatar
Default + 1 on wheel bearing
While probably not horribly expensive to remedy, I am hoping that it's just that. Diff... get it checked, too, just in case.
Old Apr 24, 2025 | 10:33 AM
Thunder Dump's Avatar
A tire out of round can cause that type of noise too.
Old Apr 28, 2025 | 11:52 AM
Default Initial thoughts from indy mechanic
He put it up in the air on the hydraulic stand; he was in the car giving it some gas, his assistant under the car with the listening device (metal rod like stethoscope?)
At first he couldn’t get it to go faster than a very slow speed. We turned off traction control by holding down the DSC button for 5 seconds, then we were able to get the speed up.
The positive is, when up in the air, with no load on the rear tires, the sound is not present. So unlikely the rear differential.
The likely culprit with the info we have now is: rear left tire or rear left wheel bearings. The wheel does not wobble when pulled side to side, so they’re thinking tire.
We’re going to swap the left and right rear tires to see if the sound shifts side when driving.
Fingers crossed it’s just a tire.
Old Apr 28, 2025 | 01:31 PM
Default Not tire
Tires swapped, and no luck. Sound still coming from left rear, even after tire swapped. Indy going to schedule me for wheel bearing job.
Old Apr 28, 2025 | 02:08 PM
DJS's Avatar
DJS
As far as I know, Jag doesn’t sell bearings, just the whole hub. Replaced the front left on my XE last year (loud speed-sensitive whine) [happily, it wasn’t the front differential, which is what I thought.] I suspect I’ll replace the front right hub this year, as I’m hearing noise again. Only 50k miles.
Old Jul 22, 2025 | 05:43 AM
Default Solution
Quick update:
Bought the wheel hub from local Jaguar dealer. Had it installed by an indy mechanic I trust; he said the wheel bearing was sold separately from the hub, so he obtained it for me from the same Jaguar dealer.
He installed both hub and bearing on driver side rear wheel.
Rhythmic whoop noise gone!
Old Jul 23, 2025 | 11:25 PM
M3 Wrath's Avatar
Great job - thanks for sharing. You've probably saved the rest of us some trouble if we ever come across the whoop!
Rotax
Jun 13, 2024 02:24 PM
Mac Allan
Apr 23, 2024 08:19 PM
Dawson994
Dec 1, 2023 01:17 PM
2003JagStr
Dec 23, 2022 01:44 AM
JaguarXJR02
May 18, 2013 09:11 AM
