rremiving front grill bar on 2016
Old May 24, 2024 | 05:18 PM
santacruz11's Avatar
Default rremiving front grill bar on 2016
have heard its only two bolts the hold grill bar on . have noticed two covered holes on the bar anyone know what those are
Old May 24, 2024 | 11:50 PM
Ray Ray's Avatar
Name the guy who told you that.
It’s held on by about 10 torx screws to the upper and lower grille.
Old May 30, 2024 | 12:49 PM
skizot's Avatar
@santacruz11 Which bar are you referring too? The crash/impact bar behind the grill is held on with 14 bolts (7 on each side) and part of it is directly bolted to the frame rails through an adapter piece. I would NOT recommend removing this bar. It is there for a reason. There are ways to cover it up and make it look nicer if you are running an open grill and just want to hit it. Can you please clartify what you are trying to remove? JLR almost always uses more bolts then needed. LOL
DNAer
Jan 14, 2024 09:40 PM
santacruz11
Mar 26, 2022 05:03 PM
El Gato
Nov 29, 2017 03:00 PM
ftypeguy
Oct 1, 2014 12:58 PM
Beav
Aug 16, 2013 04:30 PM
