SC Intercooler Removal
Old Jun 4, 2018 | 07:15 PM
Unhingd's Avatar
Originally Posted by 15FTypeR
What's the underside of the SC IC look like?
Originally Posted by lizzardo
I was wondering the same thing. I saw a cutaway once, but that was at the Drive Alive event, so almost five years ago.
Example off eBay.
Old Jun 4, 2018 | 07:34 PM
Unhingd's Avatar
BTW, took the car out for a lengthy drive this pm after the swap. No error codes! Must've hooked everything back up properly.
Old Jun 4, 2018 | 07:55 PM
ndabunka's Avatar
There's a first time for everything, right?
Old Jun 4, 2018 | 08:35 PM
Unhingd's Avatar
lol.
Old Jun 5, 2018 | 12:50 PM
Paul_59's Avatar
Banned
Example off eBay.
Thanks for all your posts, especially photos.
Looks like the intercooler elements are fastened with torx screws, might make upgrading the cooler easier .
Laminova cores anyone ?
Old Jun 5, 2018 | 01:35 PM
Unhingd's Avatar
Removing the cores will be more problematic than it appears. Once the screws are removed, the elements appeared to be siliconed down to the cover and there is an additional adhesive material sealing where the inlet and outlet tubes go through the cover. I gave up trying to remove those elements for fear of causing damage.
Old Mar 29, 2020 | 06:28 PM
Abdullah.rida's Avatar
Just straight up removed the IC?
would you recommend doing this on the Base V6 and what gains would I see
Old Mar 29, 2020 | 09:44 PM
  #28
lizzardo's Avatar
He did it solely for the bling. There *is* bling to be had, but no performance benefit.
Old Mar 29, 2020 | 10:05 PM
OzXFR's Avatar
I vaguely recall he said somewhere else that the extra bling radiates more heat away thereby reducing the IAT and enhancing performance.
Then again I think he was joking or at least wishful thinking!
Old Mar 30, 2020 | 12:28 AM
  #30
Unhingd's Avatar
My project involved nothing more than removing the I/C, having it polished, coated with Ceramic Pro and then reinstalling it. For bling only. Someone else had suggested that polishing it would actually diminish the heat transfer rate from the air plenum to the engine compartment. I suspect that to be spurious conjecture as the design intent of the I/C is for all of the heat exchange to occur between the air plenum and the 2 water filled heat exchangers mounted inside the plenum.
Old Mar 30, 2020 | 12:41 AM
  #31
Thanks a lot for the info guys!
Old Mar 30, 2020 | 11:53 AM
  #32
Therock88's Avatar
Looks great! Nothing wrong with "Bling" only mods....
jayartibee
Oct 24, 2017 11:18 AM
Shadow993
Dec 21, 2016 08:09 AM
ztocobra
Aug 22, 2014 01:04 PM
fergs03R
Apr 12, 2013 01:09 PM
fergs03R
Mar 18, 2013 02:26 PM
