So Jaguar never fixed the Low Battery problem?
Old Dec 14, 2016 | 07:45 PM
DJS's Avatar
DJS
1. If you can figure out the search terms, the window reset has been described many times here. It either varies by model year, or by coupe vs. vert, don't remember which. Or my manual is wrong, which wouldn't be the first time.
2. The procedure is in your owner's manual.
Old Dec 14, 2016 | 08:03 PM
jfranks's Avatar
I had a CEL come on, so I scanned it with my cheap-o scanner. The next morning I got the low battery warning message when I got in the car. I guess this would explain it. I didn't have to reset the battery. I took the car in for service and I suppose they reset it.
Old Dec 14, 2016 | 10:13 PM
Unhingd's Avatar
For the center display settings: hit the menu button on the steering wheel, scroll up or down to Display Settings, hit the menu button, scroll to the desired feature, hit menu button again, scroll right as necessary to get to the features you want. Scroll left a number of times to exit out. Full description on pages 41+ in the 2016 owners manual
For reprogramming windows (page 160):
The windows will need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted. Once the power supply is restored, reset thewindows as follows:
1. Close the window fully, and release the switch.
2. Lift the switch to the close position, and hold for 2 seconds.
3. Repeat this process a total of 5 times.Test the window, to check that one-touch operation is working correctly. Repeat the process for the remaining window.
These two steps along with the battery disconnect need to be done every time I tap into the OBD port.
Given the battle needed on the clutch problem and the Meridian issue, this battle just isn't worth fighting with Jag since there is a quick fix.
Old Dec 15, 2016 | 10:11 AM
Uncle Fishbits's Avatar
That's insane. Will ask dealer, but that sort of fix sounds unlikely?
Thanks DJS and Unhingd.... truly. Cheers!
