Start/Stop is here to stay
Old Oct 30, 2016 | 11:15 AM
Magnumforc's Avatar
Lucas, the Prince of Darkness! I well remember the old Lucas electrics and the old joke about why the British drink warm beer..because the refrigerators were made by Lucas!
The only thing Lucas ever made well, in my opinion, were the Lucas Flamethrower driving lights. They were brilliant and among the first really good lighting for dark drives.
You raise some excellent points about the stop-start issue. I agree that unless there were a pressurized lubrication system that assured oil would be available to the cylinder walls during startup there could be a deleterious effect on longevity. The molecular structure of modern oils is so much different than the old oils that adhesion to cylinder walls and moving parts remains constant regardless of heat. However, as with all moving parts, a single revolution with no lubrication probably equates to months of normal wear. So if only once per day in your 17 start-stop cycles there was a lack of lubrication, I would guess you shave years off the effective life of an engine over the period of ownership.
Every new car seems to have this idiot system, as you noted, just to obtain a bit higher CAFE average. Thank goodness you do not drive an Evoque as I had a loaner this past week and it shuddered and shook with every restart.
Old Oct 30, 2016 | 11:22 AM
DJS's Avatar
DJS
They do think about this stuff. For example, read about the 'hydraulic impulse storage device' that's part of the ZF transmission. It retains pressure so that the transmission can shift quickly on restart without having to build up fluid pressure.
https://www.dropbox.com/s/b7666doqb4...trans.pdf?dl=0
Old Oct 30, 2016 | 12:29 PM
Foosh's Avatar
Originally Posted by Shearwig
One thing that concerns me about auto stop/start is the long term effect on engine wear. I was always taught that the vast majority of engine wear takes place at startup - obviously as there's no oil pressure.
There's a massive difference between starting a cold engine, and re-starting a warm one. When an engine at normal operating temp is shut down, then re-started within minutes (or seconds), there is no significant difference in internal engine wear compared to an engine kept running. All the internal parts remain well-lubricated.
That is not the case when starting a cold engine, parts are cold, and not well-lubricated, which when start-up engine wear occurs. You can hate on start/stop until pigs fly, but added engine wear wouldn't be a valid reason to do so.
Old Oct 30, 2016 | 12:54 PM
lizzardo's Avatar
A few years back I read an article about how starter systems needed to change for auto start/stop to be practical. The old gear-drive starter motors weren't designed for the usage these systems required, and the change was going to be alternators that also operated as electric motors, and that starting would be via the belts.
I didn't follow the development (not in the industry anymore) but the current system works well. It took some getting used to, but the only issue I have now is if I'm inept enough to stall the car (manual transmission). For all other times I just decide if it's appropriate. Stop and go on the freeway? Turn it off. Surface streets with long lights? Turn it on. I thought I'd never like it but quickly got to the don't care stage. It's like the headlights. One or off as needed.
Old Oct 30, 2016 | 01:16 PM
Dogbreath!'s Avatar
I think that it works well save for a bit of clumsiness on occasional restarts. Took a bit of getting used to, but now I kind of expect it.
Old Oct 30, 2016 | 04:22 PM
Unhingd's Avatar
This is only an issue if the engine is stopped long enough for the oil to settle back out of all of the oil passages. Note that Jag requires that an engine be stopped for at least 10 minutes before the oil level can be measured to ensure that a relatively accurate static oil level can be measured. Shutting an engine down for a couple minutes at a time will not compromise lubrication. Also note, the engine automatically restarts after just a couple minutes of sitting idle. The only additional wear is on the starter. If that has been designed for this type of service, that should also be a non-issue.
Old Oct 31, 2016 | 04:52 AM
owentb's Avatar
as i mentioned in a previous thread i have a 2014 V6 S in south africa and I don't have stop start at all. I don't even have the eco button on the console - just a bigger spoiler button.
no-body else have this? i'll try post a picture this evening
Old Nov 8, 2016 | 03:26 AM
  #28
owentb's Avatar
Old May 23, 2017 | 08:00 AM
F-Pace Dude's Avatar
Default When you're older
Originally Posted by buickfunnycar.com
Still not sure what's so difficult about turning the switch off...it's the very first thing I do after pressing the start button.
My issues with *** are several, I agree it's easy to hit the button-but I forget-then at the first stop it shudders to off. There has got to be a dramatic increase in starter wear and tear-even if system was upgraded to handle this it adds to cost and complexity. Finally, do your research, the fuel savings are minuscule. I know the factories are forced to explore all fuel savings but the cost, inconvenience (drive in bumper to bumper traffic with *** on for 5 minutes-extremely annoying) and minimal savings make this a poor feature.
Old May 23, 2017 | 11:46 AM
  #30
Unhingd's Avatar
No big deal: just don't let out the clutch when you are stopped.
Old May 23, 2017 | 11:50 AM
  #31
Default *** Disengage
This is for the F-Pace, automatic only
Old May 23, 2017 | 12:52 PM
  #32
Unhingd's Avatar
As are 93% of the F-Types.
Old May 23, 2017 | 04:37 PM
  #33
JagAlb's Avatar
I have no start-stop feature/button and I am very about it... I wish every FType would be built without it, like mine. Indeed is an absurd feature in this kind of vehicle.
