Symposer fault code -- workaround?
Hi all-
I am currently replacing my plastic cooling pipes and doing the associated shipwright's disease stuff, S/C is out with all clips and tabs miraculously intact (and no bolts rusted!!); I am strongly contemplating deleting the symposer. I am deeply grateful to those who have posted detailed writeups and videos about this procedure, you deserve a special place in heaven. What I cannot find is much about the code that is thrown when the symposer connection is left to dangle, whether it causes any problem down the road, or if there is some resistor-based bodge that can be fabricated to fool the computer. I hope someone can fill me in. Thanks in advance.
As I recall, leaving the little solenoid in place also simplified things because I didn't need to do any cutting or splicing of the vacuum lines. I just put little rubber cap in place of the line that went from the solenoid to the symposer unit.
