Symposer fault code -- workaround?
Old Jan 21, 2026 | 09:47 AM
rbr's Avatar
rbr
Default Symposer fault code -- workaround?
Hi all-
I am currently replacing my plastic cooling pipes and doing the associated shipwright's disease stuff, S/C is out with all clips and tabs miraculously intact (and no bolts rusted!!); I am strongly contemplating deleting the symposer. I am deeply grateful to those who have posted detailed writeups and videos about this procedure, you deserve a special place in heaven. What I cannot find is much about the code that is thrown when the symposer connection is left to dangle, whether it causes any problem down the road, or if there is some resistor-based bodge that can be fabricated to fool the computer. I hope someone can fill me in. Thanks in advance.
Old Jan 21, 2026 | 11:11 AM
lizzardo's Avatar
I left the solenoid in place when I removed everything else, so the system is happy. It's small, so isn't really noticeable.
Old Jan 21, 2026 | 01:17 PM
rbr's Avatar
rbr
Thanks, will probably do that, seems easy enough to amputate. Pipes REALLY needed doing, the Y-pipe snapped the minute the bolts came out, it was about to let go.
Old Jan 21, 2026 | 07:38 PM
lizzardo's Avatar
As I recall, leaving the little solenoid in place also simplified things because I didn't need to do any cutting or splicing of the vacuum lines. I just put little rubber cap in place of the line that went from the solenoid to the symposer unit.
Old Jan 21, 2026 | 09:45 PM
GerbilEngineer's Avatar
As others, I just left the solenoid in place and capped the "output".
Call me ishmael
Oct 9, 2024 11:04 AM
sufi_786
Mar 26, 2023 10:01 AM
kbeachy
Feb 14, 2014 07:07 AM
jagman96
Aug 11, 2010 10:35 PM
