Tail Pipe Tip Cleaners
Old May 21, 2015 | 11:11 AM
Tahoe Dave's Avatar
Default Tail Pipe Tip Cleaners
Here is a before (left) and after picture of the cleaned and polished tail pipe tips. Not sure what others are using however the Wrights silver cleaner seems to do a mighty fine job.
Old May 21, 2015 | 11:27 AM
Schwabe's Avatar
Magic eraser, one wipe, done ...
Old May 21, 2015 | 11:50 AM
DJS's Avatar
DJS
Magic Eraser is an abrasive, so I'd be careful with that.
Old May 21, 2015 | 03:03 PM
F-typical's Avatar
Microfibre cloth dipped in the wash bucket. As time moves on, Autosol may be required, but not so far.
Old May 21, 2015 | 03:16 PM
TXJagR's Avatar
They just look better with tons of carbon build up. Lets others know that you really DRIVE the car.
Old May 21, 2015 | 07:20 PM
Not on an F type, but on my Audi A6 from new and now at 118k miles the tips still look like new.
The tips on my XJ although barely a year old again still look like new.
The only treatment I give them?
They get thoroughly washed every time I wash the car ( which is often ) EVERY time as part of my wash routine........
It really is that simple.
If they do need to be brought back at any time, I've used Autosol on others with great success
Old May 21, 2015 | 11:00 PM
Foosh's Avatar
+1, with a little car wash soap. That's all I've needed.
Old May 22, 2015 | 07:08 AM
OzRisk's Avatar
I use Eagle One Nevr-Dull to clean the pipes and all the chrome on my Harley. It's a merino wool impregnated with polish. Does a fantastic job.
Eagle One Nevr-Dull Wadding Polish
Old May 22, 2015 | 11:55 AM
buickfunnycar.com's Avatar
Originally Posted by Foosh
+1, with a little car wash soap. That's all I've needed...
Seems to me the V6 tips stay remarkably clean whereas the V8's are sooty as all hell,must dump way more fuel.
Old May 22, 2015 | 12:20 PM
Foosh's Avatar
Mine get fairly sooty by Friday before the weekend wash.
However, I'm in dynamic mode and manually shifting virtually all of the time. There's a lot more popping and crackling when you drive it that way, which means more fuel dumped in by the ECU to create those lovely sounds.
Old May 22, 2015 | 03:26 PM
TXJagR's Avatar
Speaking of all that fuel... Anyone have ANY idea of what that's going to do for the longevity of the cats?
Old May 22, 2015 | 05:38 PM
Unhingd's Avatar
They'll last a lot longer running rich* than running lean. *Don't know this for certain yet before we get it on the dyno.
The extra fuel blown through for the popping will keep the valves cooler. If they switched to EPAS out of concern for the fuel economy, I don't understand how blowing the fuel through for the sound is consistent with that concern.
Old May 22, 2015 | 06:07 PM
TXJagR's Avatar
sorry, should have been more clear... Cats didn't mean Jaguar... Cats meant catalytic converters... my bad...
Old May 22, 2015 | 07:40 PM
Unhingd's Avatar
No, my misread.
Cataclysmic (not a typo) Converter life could be shortened if the excess fuel dribbled into the system for the sound causes the cat to get too hot.
Why Did My Catalytic Converter Fail?
Hopefully, Jag didn't exceed the limit.
Old May 26, 2015 | 12:36 PM
Schwabe's Avatar
Magic eraser is no more an abrasive than any metal polish which all have some polishing agent in them ....
Old May 26, 2015 | 12:45 PM
DJS's Avatar
DJS
Likely true, but worth being aware of.
Melamine foam - Wikipedia, the free encyclopedia
Old May 28, 2015 | 08:23 AM
domino_z's Avatar
i use p21s polishing soap as a maintenance cleaner - it's a bit unique in being a hard waxy block that you wipe over with the supplied sponge applicator wet. can do it while the car is soaped down
and every now and then use optimum metal polish
P21S Polishing Soap
Old May 28, 2015 | 08:57 AM
K.Westra's Avatar
This stuff is good too:
Old May 28, 2015 | 10:32 AM
Unhingd's Avatar
P21S Polishing Soap
I like the blue-burnt look. I would leave it that way.
Old May 28, 2015 | 02:25 PM
Tel's Avatar
Tel
Mine get a good sponge out with ph neutral car shampoo when I wash the car. If there is any soot that is stubborn, I wouldn't use anything more abrasive than Meguiars ScratchX.
Trials on many concours chrome bike exhausts has proven ScratchX to be the best for keeping the chrome good. I found wadding and metal/silver polishes too abrasive.
