Take off your engine cover!
Old Sep 6, 2016 | 07:23 PM
  #61
Ubad2's Avatar
Banned
Default Got it !
Originally Posted by OzXFR
Simply pull it off, straight up, with a light tug in three places.
You can see the three mounting "prongs" in Mbourne's pics, the black round things poking up from the S/C cooler, two at the rear and one at the front. They slot into removable plugs/sockets on the underside of the cover, you can even see one of these plugs still attached to the prong in the third pic. One hint - if/when you go to put the cover back on, make sure you have the plugs in the cover and not on the prongs, much easier that way.
Also, once you have removed the cover you can remove the prongs if you want, they simply screw out with a 10 mm spanner.
Thank you ....
Old Sep 6, 2016 | 07:26 PM
  #62
Mbourne's Avatar
Thanks for noticing that prong gasket. I hadn't noticed that was still there. Just took it off and returned it to the cover.
Old Sep 6, 2016 | 07:27 PM
  #63
IronMike's Avatar
Never mind. duplicate response.
Old Sep 6, 2016 | 07:29 PM
  #64
Unhingd's Avatar
Originally Posted by Ubad2
Will you please explain a bit on how the cover should be removed without doing damage.
Do you simply pull upward until it comes off?
How much force is required.
Thank you
Lift straight up simultaneously on any 2 adjacent corners and apply progressively more upward force until those corners pop loose. Then do the same thing to the remaining 2 corners. There are 4 ball topped pegs that snap into the sockets on the underside of the cover.
Old Sep 6, 2016 | 08:07 PM
  #65
MaximA's Avatar
I ran my XKR without a cover for 3 years, no issues with the paint. At times it would over heat due the tune and obvious track use, but it didn't happen as much when I removed it.
So much more airflow with out that movers blanket on the engine.
Old Sep 6, 2016 | 09:36 PM
  #66
lizzardo's Avatar
I'm still sure it's four. Not sure where the three keeps coming back, but maybe it's a model thing. This is NOT the Holy Hand Grenade where, we all know, three shall be the number of thy counting, and the number thou shalt count shall be three.
Old Sep 6, 2016 | 09:43 PM
  #67
Mbourne's Avatar
It's definitely four but........you can always lobbeth it and blow thine enemies to tiny bits.......for they are wicked in mine eyes. Excuse me while I consult my book of armaments
Old Sep 6, 2016 | 11:14 PM
  #68
OzXFR's Avatar
Yep, my bad, for some strange reason (failing eyesight???) I saw only three prongs in Mbourne's pics when if I look again I can see four!
Old Sep 7, 2016 | 01:53 AM
  #69
bjg625's Avatar
I see no visual reason to take cover off.
Old Sep 7, 2016 | 06:22 AM
  #70
Unhingd's Avatar
Agreed. Top of the engine is butt ugly. The cover has been removed to reduce engine temperatures (by the factory on the SVRs & P7s, by some of us on the other models).
Old Sep 7, 2016 | 10:50 AM
  #71
DPelletier's Avatar
The engine may be ugly, but the cover is also ugly IMO as well as cheap looking. I can do without it from an aesthetics perspective.
looks better without, lower temps, less weight.....win, win, win.
Dave
Old Sep 7, 2016 | 11:20 AM
  #72
Frenchy's Avatar
So after following this thread, I just removed my engine cover and noticed that it has a foam insulation layer on the underside. This, I believe, is new to the MY16. Previous MYs had no insulation. (Please correct me if I'm wrong.) So I'm wondering: Is this thermal or acoustic (unlikely) insulation? Why was it added? Was it added for a reason that would indicate that we should keep the cover on?
Old Sep 7, 2016 | 11:32 AM
  #73
Unhingd's Avatar
Probably meant to protect the cover more so than anything else (like the hood).
Old Sep 7, 2016 | 11:53 AM
  #74
DPelletier's Avatar
I will check mine to see if there was a change but based on the information in this thread (i.e. temp at the hood surface is LESS without the cover), I'd guess that the insulation was added for acoustic (NVR) reasons.
Dave
Old Sep 7, 2016 | 12:34 PM
  #75
IronMike's Avatar
I have a 2015 "R" and the foam insulation you speak of is present on the underside of my cover...
Thus, not a 2016 model year addition. Could be a based on engine size.
Old Sep 7, 2016 | 12:56 PM
  #76
Unhingd's Avatar
Its on the '16 V6S as well.
Old Sep 7, 2016 | 07:07 PM
  #77
Mbourne's Avatar
Mine is a 14 and the cover has foam as well. all it seems to do is retain more heat and dampen some vibration from the cover. All in all two strikes against the cover.
Old Sep 7, 2016 | 07:08 PM
  #78
Dogbreath!'s Avatar
I amazed that a discussion of whether or not a heat shield is needed has taken 77 posts.
Old Sep 7, 2016 | 08:26 PM
  #79
Unhingd's Avatar
Oh, good...now we can spend another 77 posts discussing the social science behind spending 77 posts fully contemplating a matter for which an empirically established conclusion was submitted in the 1st post.
Old Sep 7, 2016 | 09:23 PM
  #80
Uncle Fishbits's Avatar
https://m.youtube.com/watch?v=SNTzOBKs1bA
3, sir!
