Tow Hook GoPro Mount?
Old Sep 19, 2020 | 05:55 AM
MisplacedPriorities's Avatar
Default Tow Hook GoPro Mount?
Is there a GoPro tow hook mount that works for Jaguar F-Types? I've only ever found license plate tow hook mounts...
Old Sep 19, 2020 | 06:19 AM
Unhingd's Avatar
You’ll need to purchase the license plate mount and adapt it to the GoPro. The 20mm reverse thread is so obscure that you can’t even find custom tow hooks that fit.
Old May 17, 2021 | 05:57 AM
*bump*
I just found someone that makes it. https://www.cravenspeed.com/the-tow-...jaguar-f-type/
Just bought one, will find out if it works or not.
Old Jun 7, 2021 | 08:06 PM
Yup, it works beautifully.
Old Jun 7, 2021 | 10:27 PM
Borbor's Avatar
I haven't done it but wouldn't it just be simpler mounting your go pro base through the eyelet of the OEM towhook with the appropriate size washer or shim and a longer fixing screw or a shaped shim/mounting plate from underneath
( eg : ___/I I\___ ) with the normal screw
Old Sep 4, 2021 | 12:57 PM
Eubster's Avatar
Just wanted to say thanks to the OP for posting this. I'm doing my first track day next week and purchased this mount for a GoPro (because does it even count if you don't film it?). I did a little test run yesterday and it was rock solid and definitely makes me feel more comfortable than a suction cup mount would at track speeds/forces.
Dochands
Jul 2, 2015 05:51 PM
kr98664
May 24, 2015 09:57 PM
martin fothergill
Mar 19, 2010 09:13 PM
