Track alignment for an f type R 2016 coupe
Old Apr 30, 2017 | 10:17 AM
ronh's Avatar
Default Track alignment for an f type R 2016 coupe
What is the camber %
Old Apr 30, 2017 | 12:30 PM
Unhingd's Avatar
You want to run around a negative 2-2.5 degrees in front . The rear is not adjustable but you can get it out to about neg. 2.5 degrees if you lower it with the H&R springs. The VAPs will probably get you to neg. 2.25 degrees.
Old Apr 30, 2017 | 02:22 PM
ronh's Avatar
Old May 2, 2017 | 12:23 PM
ronh's Avatar
Thank you for the info
Just to be clear my car is all wheel drive
Old May 2, 2017 | 01:59 PM
Matttheboatman's Avatar
Getting the extra camber surprisingly will have little to no effect on your track times. But, the suggested 2 - 2.5 on the fronts will help immensely with tire wear as the fronts get worn out on the edges.
Old May 2, 2017 | 02:02 PM
ronh's Avatar
Thank you for your reply
would you not do anything to the rear tires?
