Use of Ctek 8-step Charger/Maintainer on a Two Battery F-Type
Old Aug 1, 2019 | 09:35 PM
OzXFR's Avatar
Originally Posted by DJS
You can also disable it via a tune. I have an older SmartTop without that feature.
Yep, VAP offer this option with their tunes.
I don't have it in my VAP tune as I got my tune before they offered this option.
I could get a new tune from VAP with it but I don't see the point as my disconnect the earth lead method has worked perfectly from day one.
Old Sep 27, 2020 | 01:52 PM
Ernie1234's Avatar
Ah the beauty if capitalism....!
Old Jan 25, 2021 | 07:44 AM
Tony Castle's Avatar
Default Ctek Multi US 7002
Ref: 2021 Jaguar F-Type R
Quick question...regarding the Ctek Multi US 7002 charger, does this come with the lighter adapter & is this the easiest approach?
Thanks, Tony
Old Jan 26, 2021 | 12:30 PM
Unhingd's Avatar
Thanks, Tony
The lighter circuit shuts down at some point when the ignition is turned off, so that will not work to keep a charge on your battery.
Old Mar 5, 2021 | 10:00 PM
davidlg16's Avatar
wrong post
Old Dec 4, 2022 | 08:56 AM
madomystrong_2's Avatar
It is just a battery!! Jaguar does not want you to damage any of the electronics . Avoid this by disconnecting.
Old Dec 4, 2022 | 01:31 PM
sov211's Avatar
[QUOTE=madomystrong_2;2591645]It is just a battery!! Jaguar does not want you to damage any of the electronics . Avoid this by disconnecting.
If by this posting you suggest that the battery be disconnected instead of using a battery minder to keep the battery charged, you might want to read the threads related to the CTEK units and others. Disconnecting the battery is NOT the answer.
But perhaps I have misunderstood your posting. This is an old thread,in any case.
vet4scuba
Feb 23, 2026 03:50 PM
vika01
Mar 7, 2021 10:00 AM
Sterling Smith
Dec 11, 2020 03:46 PM
Alisher
Jun 30, 2019 02:30 PM
tai4de2
Sep 16, 2014 11:20 AM
