V6s Rwd or Awd ?
Old Oct 18, 2022 | 12:58 AM
Sebaducator's Avatar
Default V6s Rwd or Awd ?
Hi
actually looking for a coupe V6s
I have a question , could you please help me
it seem’s that this motor was available with Rwd or Awd
did’you know if it was an option , 2 different versions or maybe depends of the year of production ?
many thank’s
Old Oct 18, 2022 | 01:07 AM
OzXFR's Avatar
Originally Posted by Sebaducator
Hi
many thank’s
Fairly sure it depends on year of production and market, sorry can't say anything more definitive than that.
For example in the US and Canada the F-Type R (V8) became AWD only from I think 2016 onwards while in other markets you could still get a RWD version, and the P450 (detuned version of the V8) is available in both RWD and AWD.
But one thing for sure with the V6 regardless of market is the manual trans version was only ever RWD never AWD.
Old Oct 18, 2022 | 03:51 AM
malbec's Avatar
Option.
Check through the brochures….
https://www.auto-brochures.com/jaguar.html
Old Oct 18, 2022 | 06:34 AM
DJS's Avatar
DJS
AWD wasn’t available for the first few model years, only RWD.
Old Oct 18, 2022 | 06:49 AM
jcb-memphis's Avatar
I have the AWD in my 2016 - wonderful car. Very much the best of all worlds for the street...rain/snow mode for more of a quattro even torque....super planted. For other modes, it is probably 90% rwd biased but on a standing start the traction is immense.
Yes, a little heavier, and you need to deal with the fluids in the transfer case and front diff...but I like it. I am very pro awd though so am biased.....I use it all year and we see severe weather sometimes.
I have always loved stick but the ZF is pretty amazing.
Old Oct 18, 2022 | 07:59 AM
scm's Avatar
scm
Another advantage of the AWD is that the hood vents are positioned further down the hood so don't drip water over the injectors and/or plugs. There are rubber covers in the engine bay under the vents to deflect any water ingress.
Old Oct 18, 2022 | 10:38 AM
uncheel's Avatar
RWD vs AWD in the V6-S depended on year. As stated above, the early years did not offer AWD. Personally, in the V6, I'd be fine either way, although if I lived in a snowy region, I'd definitely perfer AWD. In milder weather, RWD just adds to the fun. So, depending on whether you're in the European Moselle vs SC Moselle (others?), it would make a difference.
As an aside, if you were to look at the V8's, I'd opt for AWD. You get plenty of rear end fun out of the V6, and I'd prefer AWD to manage the added HP of the V8. (Not that I'd kick one out of the bed.)
Old Oct 18, 2022 | 10:55 AM
eeeeek's Avatar
AWD became an option for the V6 in 2016 (US Model year). It continued on as an option until the end of the V6.
Old Oct 18, 2022 | 12:38 PM
MajorTom's Avatar
Bienvenu! I assume that you're not far from my neck of the woods. As others have said it was an option.
I'm obviously a bit biased but think that the best setup for a V6S is RWD. Less weight, no front transfer case etc and you get the limited slip diffferential. You also get the launch control feature if you want to be really quick off the line. I daily my car all year, think the AWD is pretty pointless in our part of the world and I never had any traction issues except when the OEM P Zeros were reaching the end of their life. With a set of MPS4S it's rock solid in the summer and for the winter you're fine with a set of winter wheels.
The AWD makes perfect sense with the V8 though and I have to say it's a really good system. I had it with the same V6 engine in my old XF and it was clearly very rear wheel biased although it made the car heavier and thirstier.
Old Oct 18, 2022 | 01:24 PM
yeah MajorTom l we are not so far
The car will not be a daily , but a week end car
I love rwd car , and i will look for a RWD only
Old Oct 18, 2022 | 01:34 PM
eeeeek's Avatar
On the F-Type. the normal bias for the AWD system is 100% RW.
Old Oct 18, 2022 | 02:06 PM
MajorTom's Avatar
Yeah then RWD sounds like the obvious choice for you. Good luck with the search!
Unless you already tried that we have the best driving roads in the region in northern Lux. Insanely good twisty roads, no cameras or police and hardly any traffic. And the other week I did Route des Cretes in the Vosges (again). The F-Type is just fantastic on roads like that.
Old Oct 18, 2022 | 02:20 PM
malbec's Avatar
TheStig
Jan 25, 2022 07:57 PM
mmmjag
Sep 22, 2021 07:21 AM
stmcknig
Oct 16, 2016 02:53 PM
Totti
May 20, 2015 02:39 PM
Scott B
Nov 26, 2014 03:41 AM
