What's the approximante window for checking oil level
Old Dec 28, 2019 | 05:08 PM
OzXFR's Avatar
Originally Posted by fujicoupe
Checked mine approx. 24 hrs. after car was last driven and it did give a reading, albeit 3 marks below full (one mark above mid point).
Maybe it's just an early model vs late model thing, but my oil level reading has never varied by even a micron (except once, see below).
11 minutes after shut down, 11 hours after shut down, two days after shut down, ambient temp 40 F, ambient temp 100 F, it always and I mean ALWAYS reads exactly smack on the "max" mark. Also I have never once topped up the oil in 39 months of ownership.
The one exception was the first (and so far only time) I used the vacuum pump top extraction method where I added the required 7.25 litres but the level read "overfilled", and I later discovered that I had extracted only some 6.5 litres due to miles out volume markings on the pump container - it read 7.25 litres when it was really only 6.5 litres.
Old Dec 28, 2019 | 05:32 PM
scm's Avatar
scm
Originally Posted by OzXFR
Maybe it's just an early model vs late model thing, but my oil level reading has never varied by even a micron (except once, see below). 11 minutes after shut down, 11 hours after shut down, two days after shut down, ambient temp 40 F, ambient temp 100 F, it always and I mean ALWAYS reads exactly smack on the "max" mark.
My MY18 is the same, never had to top it up, and the only time it doesn't show "max" is when it's not dead level when parked. I don't do huge mileages, but do use most of the throttle travel most of time.
Old Dec 29, 2019 | 03:57 PM
HalcyonDays's Avatar
RacerX, you were spot on. I took it to the dealer and the Shop Foreman added exactly 1 quart. Now it reads Full. Thanks for the insight.
Old Jun 6, 2020 | 12:58 PM
FIRE550's Avatar
My oil reads 2-3 clicks below maximum okay oil level in the morning. Then after driven and then cooled down for 10 plus minutes it reads perfect at the okay max level (where I think you want it ).
I don't know what the hell I should be doing because of this. Leave it alone or add. Drives me nuts and only started doing this since I did the oil change a little while ago. Very annoying.
Old Jun 6, 2020 | 06:17 PM
frank barone's Avatar
I had the same reading, just below max when cold in the morning. I’ve had my my16 s coupe since last August and it always showed full when cold that changed after my oil change at Paramus Jaguar. I spoke to AJ (Anthony Nguyen service advisor) about this and he said bring her in the next day. Connor the service technician checked the car over and stated that when cold it could show below max level, after driving and checking after 10 minutes it should show max. I’m happy to report that Connor was correct. I check my oil and tire pressure every time before I take her out for a drive. I’ve had very good service with Paramus Jaguar with AJ and Connor who are the only ones assigned to my jag. I have no hesitation recommending this dealer for service and suggest you ask for AJ and Connor specifically.
Frank my16 s storm grey coupe with brogue interior ivory stitching performance seats
hudson valley ny
Old May 5, 2025 | 03:21 PM
inmanlanier's Avatar
Originally Posted by RacerX
Measuring capacity in/out on my last oil change, I realized that the middle of the "OK" range is a full quart low. The bottom line of the "OK" range is 2 quarts low. So you want to be 75% or higher.
As an FYI - I just for the first time had to add some oil in my 2016 F type R. The scale (fully cold) was reading about halfway (mid scale). Reading the above, I almost added the full quart but realized 'trust but verify'. I swagged a pour of 1/2 of the quart; it turned out to be adding 18 ounces. Today when checking the oil warm (after sitting a couple of hours from a drive) the scale was right at full.
Thought I'd share the data. Thanks to all that share their experiences - forums are AWESOME!
DPK
Apr 20, 2024 08:37 AM
Holy F type
Aug 12, 2019 06:05 PM
carzaddict
Jul 29, 2018 04:39 PM
pk4144
Dec 2, 2016 10:18 PM
jrwb
XJ40 ( XJ81 )
23
Jul 16, 2012 05:30 AM
