WHEELS !!!
Old Jul 17, 2017 | 09:24 PM
frank james's Avatar
Default WHEELS !!!
Please if anyone can advise ?? --- I have a 15 f type r with tornado black wheels and 15 mm spacers with vap lowering springs -- think the offset is 55 front and 38 rear ? --- 9 inch front and 10 1/2 rears ---- want to get Ferrara fr1 wheels in same wheel width the offset is 35 front and 38 rear ---- does this mean that if I use no spacer on the front wheel it will stick out 5 mm more than my stock toranado wheel with spacer and if I use the 15 mm spacer on the rear it wii be the same as stock tornado with spacer ( what wheel shop said )
Has anyone used this ser up ??? Any help GREATLY APPRECIATED !! ----- lastly what are the black tornados with caps worth ? --- anyone interested ?
Old Jul 17, 2017 | 11:07 PM
FR500GT's Avatar
Give Branden (SigsJag) a few minutes and I'm sure he'll get you squared away. He's a dealer for Ferrada.
Old Jul 18, 2017 | 08:59 PM
Unhingd's Avatar
Your front tornados have a 52mm offset. The Ferraras will stick out the same as if you had 17mm spacers on the Tornados. I think you are good to go.
Old Jul 19, 2017 | 09:38 AM
Thanks -- but from what my research has led me to believe the stock front wheels are 55 mm offset ? ---- if that is correct they will stick out 5 mm farther than my tornados with the 15 mm spacers ---- and both the toranado and the Ferrada are 38 mm offset so if I can use the 15 cm spacer with the Ferrada they should be exactly the same ? Thx for all the help
Old Jul 19, 2017 | 10:24 AM
wakemcs's Avatar
Do the Ferrada's not come in a proper offset for the rear?
Old Jul 19, 2017 | 11:59 AM
SigsJag's Avatar
correct the rears will be the same as the dimensions are the same
Old Jul 19, 2017 | 12:00 PM
SigsJag's Avatar
Ferrada's indeed are offered in the proper offset for the F Type
Old Jul 19, 2017 | 01:36 PM
FR500GT's Avatar
Using a 15mm spacer on a +38 offset would equate to a +23 offset pushing the wheel FURTHUR out of the fender.
Use this calculator to better understand how it works:
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
Old Jul 19, 2017 | 02:26 PM
Yes -- but the stock rear 10.5 inch tornado has +38 offset and I'm running a 15 mm spacer lowered on vap springs on it and it's not pushed out further than the fender and lots of jags are running 17 mm ??
Old Jul 19, 2017 | 02:59 PM
FR500GT's Avatar
Sorry, your question was confusing. So the answer is yes, you can run the 15mm spacer on the rear with the 10.5" +38 wheel, making it a +23 setup. But I believe they offer a correct wheel for the rear that won't require the spacer. Branden would know!
