1999 Jaguar Sovervin X 308
Old Nov 4, 2020 | 07:30 PM
Johncos's Avatar
Default 1999 Jaguar Sovervin X 308
Hi from Australia
Had this car towed in , apparantly the car engine cut out when driving after traverling about 15 klm's . Has no ignition warning lights , no crank . The battery is fully charged and ive checked the battery feeds to the relays and fuses in all 4 fuse/relay boxes and OK .
If i bridge out the Ignition relay in the fuse/relay box in the engine bay the car will crank but not start and still no ignition warning lights . If i try to plug my scan tool i get no communication and on the also the LCD display in the centre of the instrument cluster says "wrong part fitted ", gearbox fault , and a few other signs . Ive lcated and checked the key reader and modoule , immobilizer modoule , removed instrument cluster and all looks good ???
Can anyone help ?
Regards John
sogood
Nov 10, 2021 11:47 AM
3thanol
Feb 5, 2013 02:02 PM
JackJ
May 25, 2011 03:30 AM
JackJ
Mar 11, 2011 01:04 AM
Soccer6planer
Mar 7, 2010 12:10 PM
