2004 XJ8 vibration at higher speeds above 60mph
Old Feb 10, 2009 | 05:14 PM
ken@britishparts.com's Avatar
It does sound wheel related. Does the vibration come through the steering wheel or the body and seat? Trying to zero in on front or rear wheel.
Old Feb 10, 2009 | 06:59 PM
JagtechOhio's Avatar
qz,
There were a number of posts on this topic, perhaps last spring. If you search through archives under FactoryJagTech, I think you'll get there.
Old Feb 18, 2009 | 09:36 AM
tclark's Avatar
Default 2004 Vanden Plas vibration
I have the same "beat" type vibration in my 04. I've eliminated the possibility of it being the wheels by replacing the wheels and tires. Strangely enough when I put the winter tires on and put about 180# of sand over the rear axle the problem seemed reduced. I've had the Jag tech look at this a couple of times. He though that the drive shaft was the problem and replaced it with a new one (universal joints as well) and it had no effect. Other than this the car is wonderful, but this issue really concerns me.
Old Feb 18, 2009 | 05:02 PM
hlgeorge's Avatar
I had the same issue. Took it to a tire shop that did on car balancing and they cleared it up.
Old Feb 19, 2009 | 04:16 PM
tclark's Avatar
Default Tires
As luck would have it I live 10 minutes from the Tire Racks South Bend, IN. facility. They do use the Hunter Road Force system to balance the tires purchased there, but having it done again probably wouldn't hurt things.
I did take a 4 hour round trip to Chicago today and found that at 70 mph the vibration (beat) goes away.
Thanks for the information.
Old Feb 19, 2009 | 06:25 PM
Real_Tech's Avatar
The Hunter roadforce balancer is mandatory equipment at Jaguar dealers and has been since at least 2001. Unfortunately that doesn't mean the wheels were actually roadforce balanced. To properly roadforce balance the wheels and tires, they may have to be broken down and either the tire rotated on the wheel or the tire swapped to another wheel that could counteract the problem in a particular tire. Not many techs go through the trouble on a $39 balance special. Our normal charge for this sort of balancing is 2 hours for a set of 4 tires($230) which is the same number of hours Jaguar pays for this service under warranty. You still have the possibility that none of the tires will actually match to a wheel and get the roadforce numbers in spec.
tomsjag
Jun 10, 2023 10:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
mhenz
Sep 14, 2015 07:47 PM
sawduster
Sep 11, 2015 10:02 PM
Numwen
Sep 6, 2015 12:30 AM
