2005 VDP - Coolent temp sensor error
Old Apr 10, 2022 | 11:25 AM
Tabatkinson's Avatar
Default 2005 VDP - Coolent temp sensor error
Hi everyone excited to find this group! I am the owner of a 2005 VDP with 100K miles SE WI - USA and she is amazing. However……. I am getting a coolant temp sensor error, intermittently mostly pops when driving on freeway and it will put car in limp mode. Let me start with the car is not hot however the gage goes full hot and you can pull over turn key off remove key reinsert key start and she will be fine again and back to normal…. To be safe I replaced the coolant temp sensor which was a very easy job. But it did not fix the problem. Still will intermittently peg hot and go into limp mode once you slow down.
I am thinking possible a broken wire (no resistance) however the wiring bundle is very secure and looks to be in very good condition. I have not opened the conduit to find the individual wire set or traced it back to behind the motor as of yet.
Any ideas on another way to test without cutting the conduit open to hunt for a wire?
2005 VDP Tammy
Quote
Old Apr 22, 2022 | 12:55 PM
Salliemohamed's Avatar
Ok could be wiring or the actual sensor don't throw parts without a proper diagnosis
Tabatkinson
Apr 12, 2022 07:59 AM
XJ8JR
Mar 2, 2022 10:08 AM
ianritchie
Aug 22, 2017 12:15 AM
jordanmc
Nov 16, 2016 08:44 AM
gbmtkj
Jan 5, 2011 04:17 AM
