another high oil level issue
Old Sep 27, 2016 | 07:49 AM
AbyJag's Avatar
Default another high oil level issue
My 2016 F type S Manual has had disparate readings on the electronic oil level gauge
High: 10 minutes after turning engine off
High: 1 hour after turning engine off
High:2 hours after turning engine off
Normal: first thing in morning (reading at top of gauge)
The manual recommends checking 10-15 minutes after turning the engine off but I see some dispute over this on other forum pages.
Thoughts?
Old Sep 27, 2016 | 10:47 AM
Bigg Will's Avatar
I'd take it in so you get the crazy readings on record, then should you grenade the engine due to low oil you now have recourse.
