bluetooth
Old Feb 14, 2023 | 01:20 AM
adm's Avatar
adm
Default bluetooth
Can someone help me please. The Blue tooth has become inoperational since last one month in my jaguar XF portfolio car model 2011
Old Feb 19, 2023 | 04:20 AM
POD XF's Avatar
The bluetooth module is located under the carpet beneath the left front seat. A common problem is that water gather there either from rainwater via blocked sunroof drain tubes or condensation from the airconditioner. I don't imagine you have a lot of rain where you are but mine had water accumulated from the aircon. It's common for the moisture 9flooding) to affect the fibreoptic connections, which in turn causes the centre screen display to flicker. Anyway if the fuse in the rear compartment is intact, I'd be exploring the module and connections.
Old Feb 21, 2023 | 12:04 AM
adm's Avatar
adm
Default Jaguar XF Blue tooth is inoperational. Model 2011.
Dear POD XF,
Thanks for your response. I shall investigate it.
Can you pls advise me where is the Fuse located for the blue tooth module?
Thanks in advance.
Old Feb 23, 2023 | 05:49 AM
POD XF's Avatar
The fuse is in the rear compartment, can't recall which number but it is a 5a fuse, think it might even be the only 5a in that fuse board on my car.
Martin2410
XF (X260)
May 13, 2022 04:31 AM
scotsgeeza
Jun 12, 2021 06:21 PM
Chafic11
May 28, 2019 04:05 AM
Willie Will
Oct 18, 2018 09:24 AM
OCblackJag
Oct 1, 2014 08:00 PM
