Broken ECU connector cover 2013 XF
Old Jul 26, 2025 | 03:33 PM
Enzos Dad's Avatar
Default Broken ECU connector cover 2013 XF
I have been having trouble with my 2013 XF throwing out an array of codes (everything from ABS to tire pressure, up to 8 at a time). I have been clearing them with a code reader (when they clear the car runs fine) but it has become more persistent. I decided to check the ECU to see if there was a corrosion problem in the connector. When removing the connector one of the covers broke (the red cog like lever shared off on one side). Not sure how to remove the remainder of the plug which is still in the socket. This is a US XF.
BradsJag
Jul 26, 2024 05:06 PM
vibejulio
Mar 1, 2024 01:14 PM
Necromant1k
XF (X260)
Aug 30, 2022 02:51 AM
thekiltedwonder
Aug 16, 2021 03:18 AM
meanymean7
XF (X260)
Apr 5, 2019 05:37 PM
