Jaguar BBS wheel Info Compilation
Old May 4, 2017 | 06:44 PM
Maxville's Avatar
Default Jaguar BBS wheel Info Compilation
Good evening everybody!
I would like to build up a compilation for the Jaguar BBS wheels no matter if they are 18" 19" or 20"
So everybody could use this knowledge and don't need to search so long through all topics and posts.
So if you have any infos or recommendations please share it with us.
Now my first questions, are the titan wheel studs/screws reusable, or are they stretch-bolts?
What specific type of threadlock should be used and how much torque-load do the bolts need?
Best regards!
Old Dec 7, 2017 | 08:36 AM
Maxville's Avatar
Some weeks ago i started to recover my 20" Montreals, had some phone calls and infos from different sources.
First the colour, recommendation from BBS the best match VW L88Z
The trim rings, simply remove it to avoid contact corrosion.
The advice for the bolts torque should be around 15nm but please check this again and share the info if you have some!
