Lumppy47
Old Apr 16, 2010 | 08:23 PM
Lumppy47's Avatar
Default Lumppy47
i have a 1993 xj6 that wont turn over battery was out of car for three months installed a new one fully charges lights work but when trying to start just get a click out of the relay on the cowl also radio isnt working needs codes might this be the problem thanks for any help
Old Apr 16, 2010 | 08:25 PM
First post and diving straight in Lummpy...welcome to the site, usually its good etiquette to post into the new members section first with a little intro bout you n your ride.
Sorry I can't helo, but maybe someone who can will be along soon
Old Apr 17, 2010 | 06:14 AM
Thermo's Avatar
Veteran: Navy
Lumppy, from the sounds of things, you either have a bad starting relay or a bad starter. What you can do is connect up a multimeter to the post of the relay running down to the starter and watch the multimeter as you attempt to start the vehicle. If the multimeter jumps up to above 11.0 VDC, then you have either a bad starter or the cable between the starting relay and the starter is bad (you can differentiate between the two by repeating the check using the large post on the starter). If you don't get over 11.0 VDC on the output of the starter relay, you have a bad starter relay or the wire between the starter relay and the battery is bad.
Hope this helps.
Old Apr 17, 2010 | 08:43 AM
Lumppy47's Avatar
Default Lumppy47
starter is good will check rhe relays and wires thanks
MidwestJag
XJ40 ( XJ81 )
104
Apr 10, 2014 07:33 PM
