Mintex brake parts for Jaguars.
Usefull information for Jaguar owners who want to buy Mintex or just check for the correct part numbers.
However as my car is on a crossover year there are several different pads and discs for front and rear, so some extra work is necessary to get the right parts.
Enter your reg and it finds the Mintex part numbers.
http://195.59.3.154/mintexonline/WebForms/frmMain.aspx
Check if the Mintex part numbers are correct before you buy from a supplier by using this page. Type a Mintex part number in the box and it tells you which Jaguar models it is for.
http://195.59.3.154/mintexonline/Web...rtEnquiry.aspx
Having just purchased a set of front and rear pads and a pair of rear discs from Mintex suppliers (Motorfactors), I will give a review/report later on in the S-type section.
