Search: Mongoose JLR Interface Cable
Old Dec 9, 2019 | 11:33 PM
xkr_dougie's Avatar
Default Search: Mongoose JLR Interface Cable
Hi there,
some months ago I purchased the Chinese Copy of the Mongoose JLR Interface Cable togehter with the SDD Software from Car OBD2 Tools global one-stop shopping supplier ---OBDexress.co.uk called "Mangoose"
Well, the price of ~40€ seemed attractive enough for a test.
Result: Software works, Adapter works .... partly!
When using CAN-Bus communication only, the interface seems okay. But among the list of supported Protocols there's also a Protocol named ROSCO
Yesterday I tried to do some work on a Land Rover Defender from 2011.... the communication to the Alarm ECU is done using ROSCO (ROver Service COmmunications)
ROSCO uses Pin 8 of the Diag Interface .... this Pin is not even connected to the Adaptor PCB!!! Don't waste your money purchasing this adaptor when you need ROSCO Protocol
So I'm looking for an original Mongoose JLR Cable .... is there one for sale?
BR
Ralf
Old Dec 11, 2019 | 06:58 AM
xkr_dougie's Avatar
In between I'm under the impression that it might be difficult purchasing a Mongoose Pro JLR.
Therefore an additional question: what kind of diagnostic interface would you guys recommend which works with SDD and supports all necessary protocols including ROSCO?
BR
Ralf
Old Dec 13, 2023 | 05:44 AM
superuser123's Avatar
Maybe somebody knows the voltage of ROSCO diagnostic line? My range rover refuses to be diagnosed.
Old Dec 13, 2023 | 06:08 AM
xkr_dougie's Avatar
...which model year? Which diagnostic equipment?
Old Dec 13, 2023 | 06:36 AM
2007 range rover, cable mongoose pro, sotware SDD. All modules in K line, BCM, LCM, Rain sensor, ar diagnosed via gateway in instrument cluster, instrument cluster is connected to OBD port pin nr 8 and this part is already runing by rosco protocol. K line is fine it idles on high -12V. But ROSCO is 0V. I wonder what is idle voltage of ROSCO (pin nr. 8 to Instrument cluster gateway)
Old Dec 13, 2023 | 06:39 AM
xkr_dougie's Avatar
....I would assume this is CAN Bus Car
Old Dec 13, 2023 | 06:41 AM
this is can bus car, k line car, rosco car, i bus car. All possible options
Old Dec 13, 2023 | 10:33 AM
Ura's Avatar
Ura
Good afternoon colleagues, are we talking about multican now???
Old Dec 13, 2023 | 10:36 AM
Ura's Avatar
Ura
Old Dec 13, 2023 | 10:37 AM
Ura's Avatar
Ura
in this modification, the cord works with a multican through the gwm gateway unit
Old Dec 13, 2023 | 03:59 PM
yes to be exact pin nr 8 is connecting GWM. what is the voltage of OBD to GWM when idle and when communicating?
Old Dec 23, 2023 | 09:14 AM
Ura's Avatar
Ura
I can't tell you yet if a range rover with a multican is coming, I'll check it out
Old Dec 23, 2023 | 09:16 AM
Ura's Avatar
Ura
the whole problem is how we write that this pin in the adapter lands on the ground and because of this there is no connection with the multican. I checked it myself with this modification, cars without multicans work stably
nalle
Nov 29, 2019 11:47 AM
jeje
Nov 1, 2019 11:34 AM
clubairth1
General Tech Help
Mar 28, 2019 02:02 PM
Paulc732
Aug 26, 2017 01:44 PM
Halex
General Tech Help
Apr 9, 2016 09:31 AM
