secondary camchain tensioners
Old Jan 16, 2010 | 03:22 PM
Roos50's Avatar
Default secondary camchain tensioners
If i lock down the cams do i need use the crank plug also and where does it go ?
Old Jan 16, 2010 | 04:23 PM
Brutal's Avatar
you take out the crank sensor under the engine in front of the trans. remove the rubber covver and line up the oblong slot. Insert tool and snug the bolt for the crank sensor you removed to hold it in place(I actually never use that tool, I just make sure the hole is lined up and lock the cams.) The crank wont move if youre doing upper tensioners, if you do it all then use the crank lock
Old Jan 18, 2010 | 06:45 AM
SoTxXjr's Avatar
If you are doing primary and secondary chains/tensioners, you can use a bolt in place of the crankshaft setting plug in a pinch. I think 5/8" x 2" should work. No way to really tighten the bolt to hold in place, so it will move slightly if the crankshaft moves, but it will prevent major movement and acts as a visual reference to make sure the crankshaft setting hole is lined up. Not ideal, but workable.
mikiep
Dec 20, 2019 07:37 PM
Msteiner
May 16, 2016 12:19 AM
millertic
Sep 30, 2015 08:11 PM
Paulie710
Sep 28, 2015 03:49 PM
