supercharger noice
Old Apr 3, 2010 | 12:51 PM
greenbeast01's Avatar
Red face supercharger noice
i changed the coupler on the supercharger , yet it makes a weird sound like there where rocks in the supercharger.. does anyone knows if the supercharger makes a sound like that or is that abnormal?.. does that means i need a replacement?
Old Apr 3, 2010 | 04:46 PM
Thermo's Avatar
Veteran: Navy
greenbeast, based on what you are saying, it sounds like you have a bearing starting to go bad on your supercharger. Could be a fairly cheap fix if that is what it is. But, if the bearing is too far gone, could get expensive really fast.
As long as you catch this one fast before you start hearing metal scraping, you should be good. There are some pretty tight tolerances inside of superchargers and if you start getting metal on metal grinding, it will turn ugly really fast.
Old Apr 3, 2010 | 04:52 PM
well... the mech said that the bearings look ok.. but he cant figure out why is making that sound.. it sounds like rocks inside a can...
vwbusbits
Oct 13, 2015 03:43 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
