xj6 headlight problem.
Hi, i have just bought my first jag. A 2004 3.0 XJ6 only to find the headlights dont work properly. Dip beam seems to be on permanantly but main beam only works when i flash them. Can anyone help please.
Sounds like you have daytime running light enabled which would account for the dipped beams. This is set from the setup menu on the navigation screen. If you pull the light stalk it will flash but if you push forward they will be fully engaged, worth checking these first.
Philip
Philip
