I-Pace EV 2018 - Onwards
Jaguar 2022 failed Heater
Old Apr 26, 2024 | 04:00 PM
Jenpen55's Avatar
Default Jaguar 2022 failed Heater
I have a Jaguar I-Pace 2022 and all of a sudden my heater is not emitting hot air. The seat s d steering wheel still heat up. Anyone else have this problems.
Old Apr 28, 2024 | 06:17 PM
Fraser Mitchell's Avatar
So is it emitting anything ? Like cold air ?
Old Apr 28, 2024 | 08:47 PM
Jenpen55's Avatar
Default Jaguar 2023 Heater
yes I am getting cold air out. Seats and steering wheel are working as normal.
Old Apr 29, 2024 | 08:12 AM
dpiatt's Avatar
I don't have any mechanical insights to share, but it sounds like a heat pump issue. The seats and steering wheel are probably heated differently with heating elements.
Old Apr 29, 2024 | 12:37 PM
enderle's Avatar
The heat pump system circuit is separate from the heated seat and steering wheel circuits. Did you check the fuses? Also, make sure you are in Auto mode for air conditioning I've found that when it isn't in auto, it behaves strangely (as in I never really figured out how to make it work right when not in "auto"). You could also leak in the system, so it may need to be recharged. I had to do that once every two years with my F-type as it had a slow leak we could never find.
TSTYLZE
Jun 4, 2025 08:25 AM
Lawrence Watkins
Dec 10, 2022 08:52 AM
Lawrence Watkins
Aug 5, 2019 07:26 AM
dickc
Sep 21, 2015 02:04 PM
raymondo226
XJ40 ( XJ81 )
Apr 4, 2011 05:21 PM
