ZF5HP24 A-Clutch Drum (Forward Drum)
Hi,
For anyone searching for the ZF5HP24 Automatic Transmission Forward Clutch Drum, or the "A" clutch drum, my company re-manufactures this drum where the snap ring blows out. Our design is improved over the OEM design promising no failure after installation. This drum has been tested and shipped nationwide and is available direct from Transmissions and Parts Technology in the Chicago-land area. Call 630-616-8787 or email at transpartstech@gmail.com for more information. Ask for Oliver when calling.
Thank You!
Thank You!
viscoussquirrel, the price on this drum is $285 with a $100 core deposit (refundable after I receive your damaged core back). You can send me your core and that will obviously eliminate the core charge. Feel free to email me directly at transpartstech@gmail.com if you would like more information and to be able to communicate more efficiently.
Teck4Jag, I have the drum on eBay. Click here to see the drum (you can contact me direct and not necessarily go through eBay, if you need the drum)
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Thank you very much!
I would not say "grenade", but you do risk metal going through the unit and therefore getting in the filter and possibly damaging other parts in the unit. Usually when I get calls for the drum, I don't sell other parts to replace anything else damaged. So, going off of the trend, no, other parts do not usually get damaged.
Hope that helps! Regards!
