Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
"EDIT" question to moderators
Old Nov 8, 2022 | 04:49 AM
Peter_of_Australia's Avatar
Default "EDIT" question to moderators
I hope this is the correct spot for my question to the moderators of this forum...:
I created the following thread:
https://www.jaguarforums.com/forum/s...s-type-264102/
As you would see in the discussion below in that thread, Don convinced me that I cannot use Nulon ATF, which falsely claims to be suitable as replacement for Lifeguard 6.
I noticed already in the past, that I seem to be able to make corrections to the thread (which I started) and to my comments for a certain time after I wrote them. But apparently, the "edit" option disappears after a while.. !?
S0 I would like to edit my initial thread above to make sure that anyone, who would read only the actual thread and not all the comments below, would not accidentally make the same mistake of using Nulon with their false claims... - but the edit function is not there anymore...
Old Nov 8, 2022 | 05:50 AM
You are correct, the edit function is time limited.
If you PM me the correction information I can edit the post for you.
Old Nov 8, 2022 | 05:52 AM
OK, thanks. Probably tomorrow. I am currently busy writing a new thread for the X400 - drive belt & idler pulleys...
Old Nov 8, 2022 | 05:58 AM
No worries.
Old Nov 9, 2022 | 06:02 PM
Thanks, Norri.
No action required: Don put it already into my thread - I did not know, he can do that as well...
jphurlman
Apr 9, 2021 03:06 AM
