Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Viewing Images.
Old Mar 22, 2013 | 01:56 PM
Default Viewing Images.
There have recently been some issues with viewing images.
Notably 'expanding thumbnails' or not as maybe the case.
If you are experiencing a problem, then you can make a change to your personal forum settings as follows:
Go to User CP/Edit Options and scroll down until you see The Image Resizer.
This is a 'Drop Box' with various 'bizarre' option names.
To open a Thumbnail as a Full Size Image, select the option;
Open in New Window.
Then scroll down and click on Save Changes.
The Thumbnail will now open full size in a 'new window'.
The default setting is Lytebox 3.22 but this does not seem to work!
There are other options but none of them seem to work on a Win 7 PC in IE.
Lightview doesn't work.
Slimbox doesn't work.
Thickbox doesn't work.
Floatbox doesn't work, but is interesting.
Shadowbox doesn't work, but is rather weird.
Greybox doesn't work.
Roebox doesn't work.
Lightwindow doesn't seem to do anything at all.
Awsomebox doesn't work, but you can scroll though all the images in a thread.
Highslide doesn't work, but you can move the images around with drag and drop.
If there are any more changes to the Default setting we'll let you know.
Old Mar 25, 2013 | 09:52 PM
growler05's Avatar
Thumbs up
I found that things changed a while back when CleverName pointed it out.
I found the thumbnails stopped working on my Android tablet, Andriod phone and my computers. I still run XP. :-P
Making these changes in the "edit options " section made it all work. Thanks for the fix Translator.
SCMike
Nov 25, 2015 07:55 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Fraser Mitchell
Oct 1, 2015 07:20 AM
simongulliver
Sep 27, 2015 12:58 AM
