Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
XF Message Center
Old Jun 3, 2022 | 07:57 AM
alimacno's Avatar
Default XF Message Center
When I start the car, the Red Triangle Appears and the message center shows TPMG Normal Load. This disappears after a few seconds. Should I be concerned? Any Ideas what this is?
Old Jun 3, 2022 | 08:40 AM
Welcome to the forums alimacno,
As it says at the top ...THIS SECTION IS NOT FOR TECHNICAL QUESTIONS. It is for comments and questions about the forums.
However, as you have landed here, I'll reply to the question. The message you have seen is the TPMS (Tyre Pressure Monitoring System) confirming pressures are set for normal load. The recommended increased pressures for carrying heavy loads will be shown in the Owner's Handbook. Unless you are setting off for an extended holiday with full luggage, you need not be concerned.
jgjeeper
Apr 25, 2015 08:41 PM
RSR Racing
May 29, 2013 03:32 PM
mrtalkradio
May 3, 2012 10:19 AM
