Jaguar recalls 7k F-Types for two seperate issues with electrical system
Filed under: Convertible, Coupe, Sedan, Recalls, Jaguar, Luxury
Jaguar is the latest automaker to join in on the recall action from this morning, as the British automaker has announced steps it's taking to remedy two separate problems.
The larger of the two recalls deals with an issue related to the seatbelt sensors specifically on the F-Type (we're inquiring with Jaguar if the recall pertains to the coupe, convertible or both models). According to the notice issued by the National Highway Traffic Safety Administration, "the seatbelt harness connector which connects the Seatbelt Tension Sensor (STS) to the Occupant Classification Sensor Control Module (OCSCM) may not have been correctly wired," which could result in the front passenger air bag remaining activated even when a shorter individual (child or adult) occupies that seat. As a result, the British automaker is notifying the owners of such F-Types manufactured between August 31, 2012, and October 22, 2014, to bring their cars in to their local dealership to correct the configuration of the harness connector wire.
The second Jaguar recall addresses a wider range of models but a much smaller number of actual vehicles. It affects the F-Type as well as the 2015 XF and XJ sedans, but only 272 of them in the United States. In those affected vehicles, the Front End Accessory Drive belt, Power Assisted Steering pump pulley and the battery positive cable at the alternator may detach. Since those issues could increase the risk of fire or the loss of power steering, Jaguar is calling those few affected units in to dealers to have the requisite components checked, and if necessary, repaired. Details of both recalls can be found in the notices below.Continue reading Jaguar recalls 7k F-Types for two seperate issues with electrical system
Jaguar recalls 7k F-Types for two seperate issues with electrical system originally appeared on Autoblog on Tue, 09 Dec 2014 15:56:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
More...
More...
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
