Mark V - X 420G 1948 - 1970
1963 Mark 10 (3.8) Fuel Pump Retrofit
Old Dec 18, 2016 | 05:56 PM
Lagonia's Avatar
Default 1963 Mark 10 (3.8) Fuel Pump Retrofit
One of the fuel pumps was shot and the PO used a third party fuel pump poorly attached to the fuel tank. The car was positive ground and since I converted to negative ground, I decided to retrofit newer style SU fuel pumps. The original fuel pumps are the in-tank type and there does not seem to be any availability.
I did have to drill mounting holes in the rear wheel arches to mount the pumps. At the end it worked out just fine. I also installed pre-pump filters to avoid sucking any crud into the new pumps.
Old Dec 18, 2016 | 07:55 PM
Jagfixer's Avatar
Looks great1
