Mark V - X 420G 1948 - 1970
1963 Mk 10 transmission fluid
Old Dec 7, 2019 | 04:04 AM
Yorkshirepudding's Avatar
Default 1963 Mk 10 transmission fluid
Hi
I've just joined and this is my first post.
Bought a ‘63 Mk10 in the summer and have been trying to get on top of the jobs that need doing to it.
Just wondered, what’s the recommended way to check the ATF level and, also, what ATF would members recommend for it?
Lastly, what’s the recommended procedure for draining and renewing the fluid please.
Chris
Old Dec 9, 2019 | 02:17 AM
The Mekon's Avatar
Don't own a Mark X but I presume it has the BW model 8 gearbox. Check fluid level just after shutting down engine. Drain fluid out of the pan, and replace with as much fluid as you have drained. Use Castrol Transmax F
Old Dec 9, 2019 | 04:03 AM
That’s great!! Thanks very much for that. I’ll get some ATF ordered and get cracking!
Thanks again
Chris
harvest14
Aug 17, 2018 02:41 PM
1964Daimler
Mar 13, 2017 12:03 PM
97vandenplas
Feb 19, 2015 06:12 PM
Jaguila
Feb 10, 2014 04:57 PM
BEBE JAG
Jul 23, 2010 12:19 PM
