Hi all,
This is my first post!
I have a 1959 Mk IX manual without overdrive here in Harare, Zimbabwe and I hope to take the first tentative steps towards restoration soon. Before I get started I would like to ask if anyone knows why my car might have Wipac headlights (see photos) rather than the normal 'J' headlights? It also has a pancake air filter (still to be photographed) rather than the standard one. Might these have been changed prior to the car being sent out to the tropics?
I look forward to your responses.
Regards
Fergus
Regards
Fergus
Hi again,
Please see the air filter photos attached now.
Thank you.
Regards
Fergus
Thank you.
Regards
Fergus
Regards
Fergus
Originally Posted by Fergus
Hi all,This is my first post!
Regards
Fergus
close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,009 Times in 12,222 Posts
As you already know, the OE headlamp fitted to your MK9 (and also the MK 8 and the XK140/150) would have been the 'J' type.
Wipac weren't an OE parts supplier to Jaguar but were very active in the replacement market. The likelihood is the headlamps have been replaced at some time and Wipac would have been a lower cost option than OE parts.
The 'J' type is available from SNG Barratt in the UK if you want to go for originality. Their Part Number is 5304.
The AC Air Filter is not the original type fitted to UK spec vehicles. The housing used by Jaguar was enormous:
These cylindrical filter housings must be difficult or impossible to source as I've seen a number of early Jaguar saloons with smaller chrome plated replacement filters.
If the AC is an oil bath filter, it may have fitted as an alternative if the vehicle was originally used in dusty conditions.
Hi Graham,
Thank you very much for your reply, information and photo. I guess an order to SNG Barratts one day will be necessary unless I can find a pair of decent J lamps lurking here in Zim! I know of a pretty derelict Mk IX here in Harare, which has the J lamps I think so I must go and check it out again. This car is also a manual but with overdrive, which I would like to add to mine. The owner did want silly money some time ago for me to take away the whole car though!
Regarding the AC air filter I did see what looked to be the same one fitted to a Mk IX in a classic car show room in Cape Town so maybe they were fitted as you suggest to cars which were likely to be exposed to dusty conditions. Such conditions would certainly be the case here in Zimbabwe or Rhodesia as it was when my car came here.
Regards
Fergus
Regards
Fergus
