1997 XK8 Coupe for Sale, 112k, Runs Drives and ready for a new home! $3100
For Sale
1997 Jaguar XK8
  • 1997 Jaguar XK8 - 1997 XK8 Coupe for Sale, 112k, Runs Drives and ready for a new home! $3100 - Used - VIN sajgn5743vc011961 - 112,100 Miles - 8 cyl - 2WD - Automatic - Coupe - Other - Atlanta, GA 30339, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $3,100
  • Location Atlanta, GA, 30339, USA
  • Condition Used
  • VIN sajgn5743vc011961
  • Mileage 112,100
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Coupe
  • Exterior Color Other
Description:
For Sale: 1997 Jaguar XK8 Coupe in good condition. 112k miles. Runs and drives well.
Straight body in Carnival Red / Burgundy respray, coffee interior
Solid Engine and transmission
Complete interior and exterior
Full cooling system refresh in the last year
Excellent candidate for restoration, LS1 conversion or tinker with it and use as driver.
The Good:
Starts on the first turn of the key every day since purchase, never left me stranded.
Very strong engine performance with no issues.
No codes or reduced performance concerns
Recent tune up with plugs, oil and air filter, Mobil 1, coolant flush and Dexcool fill
Complete set of covers and trims under the hood, strut tower covers, ABS cover etc.
New torque converter installed within the last year, full transmission service done at same time with OEM Jaguar fluids and filter.
Rebuilt ABS module installed in the last two years.
New AGM battery in the last year
All electrics work as designed, lights, seats, seat heaters, windows, locks antenna, etc.
Stock radio works very well with clear display and upgraded door speakers.
Full cooling system refresh in the last year with NEW Valley Hoses, metal water pump, full octopus, coolant bottle and cap, metal coolant tower, crossover, radiator hoses, heater valve hoses and remanufactured heater pump. Consistent cooling performance and excellent heat in the interior. She idled in the driveway for over an hour today in 80 degree heat and did not break 200 degrees as indicated in Torque. Both fans work very well and cycle as they should.
Underbody is dry, nearly rust free and complete with original exhaust and trims.
Very straight body with a solid 10 foot paint job
All body panels are complete, almost no dings or scratches, and very good alignment across the car. Doors close cleanly, trunk and hood are square, windows drop as they should and seal well.
New headliner and package shelf professionally installed by previous owner
Full set of Jaguar floor mats (albeit they are black)
All the rims are clean with minimal curbing or damage.
Full size spare included
All the tools are complete as is the carrier.
All trim is complete with very minor exceptions.
Interior is complete and original; the usual failure points are still there though. See more below.
Two brand new keys are included with the car
The Ok:
Car has sat for the last six months as she was replaced with an '01 coupe. She has been started and run weekly but hasn't put many miles on since the newer car arrived. Over the last week I have put more miles on her with no real issues.
Trans shifts very well but still is occasionally noisy after an hour or so of driving. The noise is similar to one mentioned in other posts on the forum discussing a buzzing / grinding noise coming from the bellhousing on part throttle around 35-50 miles an hour. The hope was the torque converter and service would solve this, but it does not seem to have completely corrected it. No codes or limited performance have been noted though.
I do not have any indication that the timing chains have been updated as she was replaced before I could get to pulling the valve covers. No noise from the chains at this point though, she idles and runs cleanly.
Power steering seems to have started to weep, probably due to lack of use. There are no noises or other issues with the system though.
HVAC settings display has blown out, all the buttons work and light as they should though.
Interior trims have failed in the usual spots (seat leather on driver side, seat trim covers, console, etc) but are still salvageable. I do have spares for some of these and they can be purchased separately if desired.
Veneer on airbag, steering wheel and trans surround are starting to lightly crack.
The CD player is possibly inop.
Body has small tweak near the rocker on the driver's side, not really noticeable but I wanted to mention it.
The paint, while it cleans up great and looks good from a distance was pretty poorly applied. She was originally black from the factory and the clear failed as they all do. It was resprayed to the new colour before I purchased her and they did not clean up any of the failed clear before paint went down. It is obvious up close but again reads well at even 5-8 feet away. Also note that the doorsills and trunk were not painted when this was done. As they are black it has not been noticeable.
The window trims will need a respray at some point as they are all peeling.
The bad:
The tires on all four corners as well as the spare are shot. They came off of the 01 I purchased as I swapped my new rims and Michelins on. They all need to be replaced.
The AC compressor has started making a terrible noise when engaged and does not seem to be working. Sadly, it worked perfectly when the car was parked. I will update this if I am able to correct reasonably.
The front suspension is due for a rework and will need to be done soon. At least shocks and shock bushings at the minimum.
I am willing to show the car in the Atlanta area as it is still insured and smogged. If needed I can deliver within a couple of hundred miles for a reasonable fee.
Please let me know if you have any other questions or would like to check out and take it home.
Old May 5, 2020 | 10:40 PM
jacobmstein's Avatar
Hello, I live nearby, would love to come check it out and see your new car! Not sure I want it, but considering.
Old May 31, 2020 | 12:51 PM
cinqueneuf's Avatar
Default A/c
Has there been any work and diagnoses on the ac?
Old May 31, 2020 | 03:03 PM
extheaterkid's Avatar
Been working on the AC over the weekend, actually. Cannot confirm that I have solved it yet as the valvecovers are off to look at the timing chains. Will let you know more hopefully tomorrow.
Old Jun 3, 2020 | 02:46 PM
Did some diagnoses over the weekend and it looks like the clutch for the AC compressor has failed. I am considering replacing it but I will increase the price of the car to reflect the work if I do so.
