1999 xjr partout
For Sale
1999 Jaguar XJR
  • 1999 Jaguar XJR - 1999 xjr partout - Used - VIN SAJPX1846XC860020 - 158,800 Miles - 8 cyl - 2WD - Automatic - Sedan - Black - Frederick, MD 21702, United States
    Sold
  • Price
    $1
  • Location Frederick, MD, 21702, USA
  • Condition Used
  • VIN SAJPX1846XC860020
  • Trim Base
  • Mileage 158,800
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Sedan
  • Exterior Color Black
Description:
Parting out my '99 x308 XJR which was recently in a wreck (front end went into a guard rail). 158.8k, everything running fairly well, still running fine after the accident, not even a leak from the rads.
Trying to sell off all the valuable bits (electronics, brakes, SC, TB, etc) and get it off my lot and sold to a yard most likely, I can't keep it around forever... This also means I need to keep it as a roller so that it can be easily put on a flatbed, so suspension is mostly out of the question (unfortunate as it was excellent and mostly redone recently). Also probably means doors/etc might be tough as it's stored outside... HOWEVER, if you're local and that interested in buying the rolling chassis (with whatever other bits I leave on there), let me know and we can work something out.
Notable bits:
Black exterior, black/oatmeal interior
R100 Brembo caliper set (silver with red text, supposedly more rare than the "standard" brembos with gunmetal grey paint and silver text)
GenV blower, installed and serviced last year with new needle bearings, new OEM-style coupler, and fresh oil. Ready to drop-in to your x308
Mostly stock otherwise, aftermarket wheels but again, roller
Spare wheel is a silver Penta in B-grade (rim edge is scuffed up, but wheel is straight/true)
No error codes, so any electronics should be good to swap in as a replacement for any troublesome ones...
Will upload some more photos as weather/time permits, but for a little more info see here: X308 forums link
Old Sep 28, 2024 | 01:18 PM
Quadcammer's Avatar
What is the condition of the interior wood, primarily the doors and passenger airbag cover?
Old Sep 28, 2024 | 09:59 PM
nilanium's Avatar
I'd say fair to good, depending on the panel. Photos will be uploaded shortly with detail.
EDIT!!! Seems like I can't edit the original listing, see this link for a photo gallery: Google drive - XJR partout link
Drivers door - a few cracks, a couple of which have started to let fading thru.
Pass airbag cover - very good, only one crack in lacquer which hasn't bled thru yet.
Pass door - few cracks, no bleeding thru yet.
Ski slope - fair, I believe it needs to be reglued to its plastic backing plate but it's intact.
Wheel - OK, starting to crack along the top a bit.
Old Oct 1, 2024 | 01:45 PM
Capek13's Avatar
I am interested in the front driver’s seat. The one in my ‘98 busted. Located in Virginia.
Old Oct 1, 2024 | 01:58 PM
Capek13's Avatar
I forgot I also need the center third brake light and housing.
thanks!
Old Dec 21, 2024 | 07:04 PM
nilanium's Avatar
Bump!!
Got someone interested in the engine (and taking the rest of the chassis with it) so this may be going away pretty soon... Let me know over PM's if you want something before it's gone!
Again, in case the link was missed earlier,
SEE HERE FOR ADDITIONAL PHOTOS:
GOOGLE DRIVE PARTOUT PHOTOS LINK
Also, got a pair of DIY spring compressors which were passed to me by Highhorse ages ago, if you have a need for them let me know and I'll send em over no charge, just send me a shipping tag or cover shipping costs.
Old Jan 16, 2025 | 09:08 AM
dubaholic2's Avatar
Are you still parting this or did you sell it? I need the rearview mirror.
