Selling Higgins my 2010 XFR
For Sale
2010 Jaguar XFR
  • 2010 Jaguar XFR - Selling Higgins my 2010 XFR - Used - VIN SAJWA0JAMR55098 - 114,000 Miles - 8 cyl - 2WD - Automatic - Sedan - Silver - Riverside, CA 92507, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $14,000
    • OBO
  • Location Riverside, CA, 92507, USA
  • Condition Used
  • VIN SAJWA0JAMR55098
  • Mileage 114,000
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Sedan
  • Exterior Color Silver
Description:
I'm selling my 2010 Jag XFR, ABSOLUTELY NOTHING WRONG WITH THE CAR, other than the following, I removed the satellite radio module as it was faulting the infotainment system and I never used it. It has a minor scratch on the driver side where I hit a traffic cone, see photos. WHAT THE CAR HAS, AND THE INSTALLS CAN BE VERIFIED ON MY POST PAGE.
MINA INTAKE AND EXHAUST
250 AMP ALT
I HAD THE FACTORY STARTER REBUILT
NEW BELTS (GATES)
NEW HD PULLY BEARINGS
At 100k
NEW PLUGS (DENSO
NEW O2 SENSORS (DENSO)
NEW MASS AIR SENSORS (DENSO)
TRANSMISSION SERVICE INCLUDING NEW VALVE BODY SEALS AND HD ALUMINUM BRIDGE SEAL (REDLINE 100% SYTHETIC FLUID)
POWERSTEERING SYSTEM SERVICED (REDLINE 100% SYTHETIC)
DIFF SERVICE (VALVOLINE 100% SYNTHETIC)
BRAKE FLUID SERVICE (MOTORCRAFT 5.1 BRAKE FLUID)
NEW SLOTTED ROTORS 4 (R1 CONCEPTS)
NEW BRAKE PADS (EBC RED STUFF)
REAR TOE ADJUSTMENT ARMS REPLACED
ALL TORN BALL JOINT COVERS REPAIRED
FUEL FILTER REPLACED
K&N AIR FILTERS SERVICED
Within the last 2 years
NEW JAGUAR WATER PUMP
ALL NEW PLASTIC WATER CONNECTIONS INCLUDING THE THERMOSTAT, EXPANSION TANK AND REAR CROSSOVER PIPE
ALL NEW HOSES INCLUDING THE HOSE RUNNING UNDER THE INTAKE/INTERCOOLER
SUPERCHARGER SERVICED
Within the last 50 kmi
TRANSMISSION MOUNT REPLACED
TRANSMISSION FLEX JOINT (GUIBO) REPLACED
Since I've had it
EURO TUNE UNDER DRIVE SC PULLEY
JAILBREAK/GSR TECHNIK SMOG LEGAL TUNE = 496 WHEEL HP
MAGNA FLOW X PIPE
BOSCH 010 INTERCOOLER WATER PUMP
BEFORE I bought it at 42kmi
The diff had been replaced
the AC condenser, cooling fan an controller had been replaced
I'm sure I've forgotten some things, but as I said just go through my post and you'll see.
I've only run Walmart Supertech 5w/20 High mileage oil changed every 2 to 3kmi.
Bubling dash was replace buy Jaguar under the air bag recall.
I HAVE ALL the stock parts except for the SC pulley which I cut off. Including
The intake and exhaust, 20' Nevis rims and tires. Plus oil filters and numerous factory spares.
CAR HAS NO LEAKS, BURNS NO OIL AND HAS NO TIMING CHAIN ISSUES!
I've had the car 6 yrs and am ready to try an AMG Benz before I retire..lol
If you have any questions please ask.
Old Jun 9, 2020 | 12:29 AM
Bigg Will's Avatar
Lowering the price to $13000.00 as that is the price on other sites.
Old Jun 12, 2020 | 01:05 PM
Adam J's Avatar
anyone in the market would be a fool not to consider your car. you've fully documented the car and details of how you've systematically combed through the car and led the way with preventative maintenance and tasteful upgrades.
seriously, anyone considering one of these cars - this car is not comparable to one at a dealer with unknown history - those cars are missing about 8k - 10k of proactive lovin that's been given to Will's car.. 13k is a steal!!!
Old Jun 16, 2020 | 07:01 PM
Jssaab's Avatar
If only an RWD car was practical here in the northeast, awesome opportunity
Old Jun 22, 2020 | 12:11 PM
Bigg Will's Avatar
Price drop to $11800.
Old Sep 16, 2021 | 01:02 PM
neruda's Avatar
Originally Posted by bigg will
i'm selling my 2010 jag xfr, absolutely nothing wrong with the car, other than the following, i removed the satellite radio module as it was faulting the infotainment system and i never used it. It has a minor scratch on the driver side where i hit a traffic cone, see photos. What the car has, and the installs can be verified on my post page.
Mina intake and exhaust
250 amp alt
i had the factory starter rebuilt
new belts (gates)
new hd pully bearings
at 100k
new plugs (denso
new o2 sensors (denso)
new mass air sensors (denso)
transmission service including new valve body seals and hd aluminum bridge seal (redline 100% sythetic fluid)
powersteering system serviced (redline 100% sythetic)
diff service (valvoline 100% synthetic)
brake fluid service (motorcraft 5.1 brake fluid)
new slotted rotors 4 (r1 concepts)
new brake pads (ebc red stuff)
rear toe adjustment arms replaced
all torn ball joint covers repaired
fuel filter replaced
k&n air filters serviced
within the last 2 years
new jaguar water pump
all new plastic water connections including the thermostat, expansion tank and rear crossover pipe
all new hoses including the hose running under the intake/intercooler
supercharger serviced
within the last 50 kmi
transmission mount replaced
transmission flex joint (guibo) replaced
since i've had it
euro tune under drive sc pulley
jailbreak/gsr technik smog legal tune = 496 wheel hp
magna flow x pipe
bosch 010 intercooler water pump
before i bought it at 42kmi
the diff had been replaced
the ac condenser, cooling fan an controller had been replaced
i'm sure i've forgotten some things, but as i said just go through my post and you'll see.
I've only run walmart supertech 5w/20 high mileage oil changed every 2 to 3kmi.
Bubling dash was replace buy jaguar under the air bag recall.
I have all the stock parts except for the sc pulley which i cut off. Including
the intake and exhaust, 20' nevis rims and tires. Plus oil filters and numerous factory spares.
Car has no leaks, burns no oil and has no timing chain issues!
I've had the car 6 yrs and am ready to try an amg benz before i retire..lol
if you have any questions please ask.
still available?
