1967 340 Heavy Throttle Pedal
My throttle pedal on my 340 seems awfully hard to push giving the car a heavy or slow feel. I have the factory return springs attached at all locations. I recall another post with the same symptoms but can't recall any fixes?
There are also a couple of rubber bungs on the throttle linkage where it goes through the bulkhead. These can become worn with age and usage. The rubber can become stiff with age and they might need replacing.
Lastly if your car is an Auto when you depress the accelerator you lift/pull the kickdown cable up. If the Bowden cable is stiff this will effect the feel of the pedal. Oil down the cable to loosen it off might help. You can check this one by disconnecting the cable from the throttle linkage at the top and see if the accelerator pedal is more free.
Michael Star
Mar 4, 2013 08:38 PM
