3.8 Engine rebuild
Old May 3, 2024 | 03:14 PM
  #121
David84XJ6's Avatar
My Lucas data base shows:
Both 3.4 & 3.8 CR 9:1 1966 Jaguar with 22D6 # 41064A distributor, with a {5/12/8} vacuum unit.
Give these guys a call, for recommendations on best distributor specs, for your compression ratio and fuel octane available.
They can overhaul and update your distributor for your planned configuration/application.
British Vacuum Unit
Canterbury, NH 03224
(603) 731-1788
​For orders or info, use our web "Contact Us" or email us direct at
https://www.britishvacuumunit.com/lu...ibutors-1.html
This thread addresses some options:
https://www.jaguarforums.com/forum/x...xj6-s2-250183/
Rgds
David
Old May 4, 2024 | 01:22 AM
  #122
Glyn M Ruck's Avatar
8 to 1 CR = Lucas 22D6 ~ 41063A ~ on all 3 of the cars I had to restore my S Type. Monster Lucas Data Base .pdf that is too large to attach here shows the same. Seems the different CR has a different advance curve. (Another Service Manual mistake)
Old May 4, 2024 | 02:40 PM
  #123
Just a few of them. Lucas made a bucket full of different spec distributors. First 20 pages. I chopped up the .pdf. Much missing data.
File Type: pdf
Old May 4, 2024 | 05:18 PM
  #124
jayd2's Avatar
There no vacuum ports on the intake or carbs. I prefer not to drill any holes to add a vacuum port. Unfortunately, I haven't found many distributors without a vacuum advance. Mechanical advance only distributors have a different advance curve.
Is there a specific reason why some engines came with mechanical advance only?
Old May 4, 2024 | 06:07 PM
  #125
David84XJ6's Avatar
PERTRONIX D171600 FLAME-THROWER ELECTRONIC DISTRIBUTOR CAST BRITISH 6 CYL PLUG AND PLAY WITH IGNITOR II TECHNOLOGY NON VACUUM
( Tailored advance curve for optimal performance and drivability)
Amazon price $285.00 Added matching coil Pertronix 45011 Flame-Thrower II 45,000 Volt 0.6 ohm Coil , Black price: $62
or (a Lucas DLB198 ignition coil, price $42 Moss Motors)
Note: you must use Electronic Ignition spark plug wires. Any Parts store can supply correct wire sets, if you ask for 1984 XJ6 S3 jaguar wire set.
I have not heard anyone comment on this unit, many Jaguar owner are happy with the Vacuum advance version. I installed Vacuum version on my 1968 XKE and it worked well. The Lucas distributor I removed was non-vacuum; It was a smog distributorto deal with lean burning at all RPMs, and like the carburetors were made to be tamperproof.
Rgds
David
Old May 7, 2024 | 08:41 PM
  #126
jayd2's Avatar
Default Moss 4 Speed Dip Stick
My Moss 4 speed has a what looks like a threaded hole in the top cover. The manual shows a small dipstick in the exploded view of the gearbox. Is this hole for a dipstick? Did they all have a dipstick? There is a threaded hole in the side of the main case for a plug, I assume that you fill the transmission to that level.
Old May 7, 2024 | 08:59 PM
  #127
jayd2's Avatar
I purchased a new Pertronix non-vacuum on Ebay for 175.00. The car I fabricated, the one the 3.4 is going into, has a SBC with a Pertronix. I've had the SBC Pertronix for about 4 years with no problems.
Old May 7, 2024 | 10:14 PM
  #128
jayd2's Avatar
Default Moss 4 speed lubricant
I've been researching oil for a Moss 4 speed. It's a little confusing, some say it must be a GL4 oil, all GL4 I've found is multi-weight, like 80w-90 gear lube. Other's have stated not to use multi-weight oil. Moss sells Redline MT-90 for manuals. Some post state specifically not to use synthetic oils, Redline is a full synthetic oil.
What is a proper lubricant for a Moss 4 speed with white metal?
Old May 7, 2024 | 11:01 PM
  #129
Jagboi64's Avatar
The original spec was SAE 30 motor oil. I have had good luck with the RedLine MTL ( not the gear oil). I suspect a synthetic 30 wt engine oil would also work.
Glyn is the oil expert and can give better advice.
Old May 8, 2024 | 01:56 AM
  #130
Moss gearbox with or without OD = SAE 30 Engine oil.
Jaguar all synchro gearbox with or without OD = GL4 90 (for easier shift when cold GL4 75W - 90)
Old May 8, 2024 | 09:44 AM
  #131
Schmitty's Avatar
I'd go with the MT-90 oil, in fact I did and I notice a better shifting experience. Just saying.
Schmitty
Old May 9, 2024 | 01:25 AM
  #132
It's all in the viscometrics. You will probably find that the MT 90 is in fact a SAE GL4 75W - 90 ~ there is no magic way of improving change with additives.
Old May 9, 2024 | 04:59 AM
  #133
Refresh page for edit.
Old May 9, 2024 | 08:55 AM
  #134
Additives can make virtually imperceptible differences that the average driver would never notice.
Old May 9, 2024 | 12:02 PM
  #135
Our MT fluid was an ISO 32 that we got away with due to the film thickness of the additive used.
Old May 9, 2024 | 06:05 PM
  #136
jayd2's Avatar
Default 3.4 spark plugs heat range
I'm looking for spark plugs for a 3.4. It's bored .030 with a "B" type head, 8:1 compression and 2 SU HD6 carbs. What would be the correct heat range for 88-91 octane fuel? Champion shows a heat range from 6-9 for engines with a "C" type head, no listing for a "B" type head.
Old May 9, 2024 | 06:14 PM
  #137
jayd2's Avatar
Default 3.4 approximate HP
My 3.4 is bored .030 with a "B" type head and 2 SU HD6 carbs. Are there several cams that can be used with a "B" head? Is there a significant HP difference between the cams? I've seen 3.4 HP ratings from around 160 to over 200HP. What's approximate HP range with the "B" head?
Old May 9, 2024 | 06:24 PM
  #138
jayd2's Avatar
Default Clutch slave cylinder hose fitting adapter - NPT or AN
Is there a hose fitting adapter for an early sedan (GR-4252-364) slave cylinder to convert to NPT or AN fittings?
What is the factory fitting thread size?
Old May 9, 2024 | 10:56 PM
  #139
Jagboi64's Avatar
I have used NGK BPR5ES with good success. I do know that Champion and NGK have different heat range scales. Champion recommends N11YC
Old May 9, 2024 | 11:02 PM
  #140
Jagboi64's Avatar
The early XK120 cars were designed for immediate post war low octane fuel, so were 7:1 compression. Later cars were 8:1 and some versions were 9:1. The pistons will determine the compression ratio and the height of the dome.
The power ratings then were gross, not net like is used now, and some of them were rather optimistic. I have tested my 3.8 with an actual compression of 8.6 and I measured 164 hp.
Some of the XK120, Mark VII, XK140 and Mark 1 2.4 had 5/16" lift cams, and the later engines all the way to 1992 has 3/8" lift cams. An engine from a Mark 1 3.4 should be 3/8" lift.
