3.8 Engine rebuild
Old May 9, 2024 | 11:14 PM
  #141
Jagboi64's Avatar
Originally Posted by jayd2
Is there a hose fitting adapter for an early sedan (GR-4252-364) slave cylinder to convert to NPT or AN fittings?
What is the factory fitting thread size?
It's a standard British brake line fitting size, I think 3/8" x 24 tpi. It's a double bubble flare that seals the line to the body of the slave cylinder, quite different from typical US brake lines. The threads are different too, it's a finer thread that standard US brake fittings.
Old May 10, 2024 | 02:34 AM
  #142
Peter3442's Avatar
As I've bought brake parts only from dedicated suppliers, I've never thought about the thread standard, but I'd assumed that they were UNF. There must be British Girling/Dunlop brake suppliers in the US.
Old May 11, 2024 | 03:17 PM
  #143
jayd2's Avatar
Default Thermostat
I need a thermostat for the 3.4. I've found 160-190 degree. What's best for summertime only driving?
Old May 11, 2024 | 03:40 PM
  #144
Glyn M Ruck's Avatar
To ensure that all coolant goes through the radiator when engine has warmed up.
Old May 11, 2024 | 06:03 PM
  #145
jayd2's Avatar
Default Exhaust System
I'm installing the 3.4 in a car I built and it will require a custom exhaust system. I like the way the XK series cars sound. Are they dual exhaust with 2 separate mufflers, or two into one? Is the stock exhaust pipe 1 3/4" diameter?
Old May 11, 2024 | 06:07 PM
  #146
jayd2's Avatar
Default Clutch master cylinder bore diameter
The car I built currently has Wilwood pedals and master cylinders. I'll be using a stock clutch slave cylinder. The clutch master cylinder should be the same bore diameter as the stock cylinder. What is the bore diameter of a stock clutch master cylinder?
Old May 11, 2024 | 06:08 PM
  #147
hueyhoolihan's Avatar
so do these cars have one of those cooling systems with a bypass pipe, hose or combination (and will be referred to as the "bypass pipe"), such that the thermostat stops the flow, completely, to the radiator when the coolant is cold, and shunts it, via the bypass pipe, directly to the waterpump, to be pumped back through the head again, and then, as the coolant begins to warm, due to its unique construction, can slowly close that bypass pipe as it simultaneously opens the one to the radiator?
if so, i've read that just any old thermostat, even if it fits, will not do, or at least will leave the bypass open at all times. which was not the original intent of the bypass.
Old May 11, 2024 | 06:53 PM
  #148
David84XJ6's Avatar
Dual Exhaust at 1 3/4" should be fine for XK 3.4, @CR 8:1. With OEM B head and OEM dual intake, you will be < 180 HP Gross.
Regards
David
File Type: pdf
Old May 11, 2024 | 09:19 PM
  #149
jayd2's Avatar
There is a bypass pipe. According to what I've read the engine can over heat with a standard thermostat. I've seen where bypass blocks with no thermostat are used in racing.
What would happen if you block the bypass and use a standard thermostat, would it tend to overheat? It wont be driven in cold weather ever.
Old May 11, 2024 | 09:27 PM
  #150
jayd2's Avatar
Regards
David
Would my engine gain much in gross HP using 2"?
Old May 11, 2024 | 09:42 PM
  #151
David84XJ6's Avatar
When you first start, the intake to the water pump will not be getting flow, until the thermostat begins to open.... with no flow the thermostat will take a long time to open.
The suction may collapse the water pump intake hose.
My Opinion: For an occasional use vehicle, If you are in warm climate and you use 5-30 full synthetic oil, you would be ok to just leave thermostat out and block the by-pass. It will take longer to reach operating temperature.
The Best plan would be to put the sleeved thermostat in as Glyn recommends.
https://www.ebay.com/itm/25605623396...MakeTrack=true
Rgds
David
Old May 11, 2024 | 10:41 PM
  #152
David84XJ6's Avatar
You would not increase HP with the 2" system, and may loose a small amount do to lower exhaust velocity. Look for aftermarket mufflers that are straight through to keep the exhaust velocity up.
My XKE 4.2 had a 1 7/8" OEM exhaust system. I did use 2" exhaust headers, as the calculated optimum of 1 3/4" were not available. I was about 40 HP lower than a 2" system called for.
There are more muffler options at 2" OD. You can use them with a pair of 1 3/4 to 2" reducers, if you can't get the right muffler size for 1 3/4".
Rgds
David
Old May 12, 2024 | 03:37 AM
  #153
Peter3442's Avatar
Since the discussion has started, these are my thoughts for the exhaust system. Keep the system standard from the engine to around the gearbox. This is where you want a good, negative reflection. At this point, you either increase the diameter of the pipe or have a crossover between the two. This should gain a few HP and some torque. In my opinion, the effect of many fancy manifolds and sports systems is mainly cosmetic (and cost. Perhaps, that's costmetic). Of course, make sure the joints/ports all match well and the castings don't have large imperfections (they are usually good).
Old May 12, 2024 | 09:12 AM
  #154
jayd2's Avatar
I've ordered one of these. This is my first Jaguar engine, I've never seen a thermostat like this.
Old May 12, 2024 | 09:37 AM
  #155
jayd2's Avatar
Default Fuel Pressure for SU HD6
Is 2-3 PSI the correct fuel pressure for the SU HD6 carburetor's?
Old May 12, 2024 | 12:27 PM
  #156
Jagboi64's Avatar
Highly doubtful. The later V12 Jaguars with 300hp used dual 1-3/4" exhaust.
Old May 12, 2024 | 12:28 PM
  #157
Jagboi64's Avatar
Yes. SU's are sensitive to too much pressure.
Old May 12, 2024 | 01:09 PM
  #158
jayd2's Avatar
There are 3 Stromberg 97 two barrels in the car now. The 97's can flood at 1 PSI, they also like boil over when parked.
Old May 16, 2024 | 03:42 AM
  #159
jayd2's Avatar
Default Spark Plug Heat range
What would be the best spark plug heat range for a 1954-1957 3.4 with 8:1 and a B type head? The engine had new Champion n12y plugs when I got it, but one plug had a broken insulator and another had minor damage to the electrode.
Old May 16, 2024 | 04:37 AM
  #160
Peter3442's Avatar
UN12Y were standard back in the day.
