3.8l engine manifold vacuum
Old Dec 14, 2020 | 01:23 PM
jalsina's Avatar
Question 3.8l engine manifold vacuum
Anyone know what vacuum a newly-rebuilt 3.8L engine should pull at idle? Thx.
Old Dec 14, 2020 | 02:43 PM
Glyn M Ruck's Avatar
16 to 20 inches Hg. Once run in and no manifold leaks etc. typically 20 in Hg at sea level.
EDIT: As reminded below drops with altitude. As a reference 15/16 at 5000ft.
The differential also drops with rising altitude. But for our purposes and range drops approx 1 in Hg (inch of mercury) for every 1000 feet is an OK rule of thumb.
If you want more accurate than that Google one of the many tables available.
Old Dec 14, 2020 | 07:13 PM
Jagfixer's Avatar
Check points, carb adjustments and timing, each time you change something vacuum can change. When all is adjusted maximum vacuum at idle.
Old Dec 15, 2020 | 12:18 AM
Jagboi64's Avatar
It will depend on your elevation too. At my elevation the atmospheric pressure is about 4 in Hg less than at sea level, so that affects the maximum an engine can develop.
Old Dec 15, 2020 | 05:51 AM
Absolutely. I should have stated Sea Level. Reduces with altitude. Corrected & embellished above with example. Thanks.
car5car
Jan 24, 2019 12:48 AM
MK2
Aug 5, 2017 11:53 AM
thedugger1
Dec 28, 2015 08:56 AM
denraden1
Jun 30, 2013 12:04 AM
