D type cams vacuum
If the cams are coming from an established tuning company, they should know. Incidentally D type cams range from standard with a few degrees extra duration to the WAD, which are still not excessively wild.
A few more thoughts:
Rob Beere is probably the most knowledgeable person on Jaguar cams. You can find him via Google.
There are E types with D type heads and engines. I don't recall them requiring a vacuum pump.
As you've posted on this subforum, I guess the engine is going into a saloon. Even a Mk2 is a fair bit heavier than a D type, which might influence the torque Vs power compromise.
tapollo
Dec 21, 2013 10:02 AM
