Digging in to my MkII
Old Mar 13, 2022 | 01:42 PM
Blue340's Avatar
I am having the same problem. I was warned by a long-time Mk2 owner not to try to change out the Thermo switch because the three screws are fragile and prone to breaking. He reports that if that happens "you will have a very bad day". It is easy to connect a lead to the Lucas connector at the Thermo switch and run it to ground in the cabin with an indicator light. I have made a temporary jumper. The car started fine at 25 degrees (F). I run the car until the temperature gauge gets to about 30 degrees (C), stop and turn off the jumper. What a wonderful thing this Forum is!
Old Mar 13, 2022 | 07:46 PM
Glyn M Ruck's Avatar
There is an easy fix to that without touching the 3 bolts.
Buy a new Otter switch
Carefully knock back the holding tabs. Do the same to the new switch, fit the new bi metal (invar) strip & plastic part.
Gently tap the holding tabs back on the new guts. & you are done.
Old Mar 13, 2022 | 08:04 PM
Blue340's Avatar
Thank you Glyn...
Guilherme Ribeiro
33
Apr 25, 2022 05:34 PM
Jag4
Sep 9, 2018 07:54 PM
Ropariva
Jul 12, 2017 10:13 AM
Cybersib
44
May 3, 2014 09:15 PM
jagspeed
Jul 26, 2012 05:07 PM
