Jaguar 420 1966 Project Car
Old Feb 7, 2024 | 04:36 PM
  #61
Glyn M Ruck's Avatar
We had already polished the stainless steel outside covers with the key holes in them to as new.
Old Feb 13, 2024 | 09:34 AM
  #62
Cass3958's Avatar
Originally Posted by JimmyKat
Hello all,
I have question related to the car key. There are no keys to the car since this was a left behind in an underground parking lot.
Any ideas how you can make a set of keys? Or would you have to replace all the lock cylinders somehow?
Jimmy
Sorry for the delay in getting to this Glyn but I was away on holiday.
Jimmy
On the S Type and I would assume the 420 is the same the ignition key is the same as the door key which is the same as the glove box key but the boot key is different again. Two keys for the whole car. The keys are known as FS keys and have numbers stamped on the key as in FS597 and this number is stamped on the barrel of the relevant lock. Getting to the number on the barrel is not hard but involves taking the locks to pieces to find them. Once you have the number of the lock there are several companies that supply replacement keys to match the number. In the past I have used this company in the UK and can highly recommend them. https://www.replacementkeys.co.uk/un...EaAqiaEALw_wcB
I had/have several spare locks which had no keys so could not be sold but I found the FS numbers and had two keys for each lock made. £3.95 per key I think they charge and the service is really good as the keys arrived within three days.
So to find the FS Numbers, below I have added some photos of the barrels to show the FS codes. Actually stripping the lock barrels out is very easy with common sense so I will not go into how you do that as it would take too long. The photos do show where some of the hidden pins are though to remove the barrels.
Rather than removing the ignition barrel or door lock barrels which both involve a lot of work if you strip the glove box lock down first and find the FS Number for that, order the FS Key to fit and then try it in the door lock and ignition. It should work but if for some reason it has been changed you would then need to strip the ignition barrel and door lock out to find the correct FS code for the door locks.
At the end I have attached a photo of a set of original keys showing the FS Numbers. Note that the key on the bottom (the larger one ) is for the doors, glove box and ignition. The key on the top (the smaller one) is for the boot lock.
Door barrel showing FS Number
Boot lock showing locating lock pin on the boot lock
Lock pin removed showing FS Number on boot lock barrel
Ignition switch showing hole into which you have to press a sprung pin to remove barrel.
Ignition barrel showing FS number
Glove box lock showing the FS Number.
Original key designs with FS Numbers
Old Feb 13, 2024 | 12:16 PM
  #63
You are allowed to have a holiday Rob. Thanks for the great input & pics.
Old Jun 25, 2024 | 08:16 AM
  #64
JimmyKat's Avatar
Hello to all of you,
Finally got the Jaguar 420 1966 project car to my home and started freshening her up!
Mildew smell, just lovely!
So can anyone tell me in order to get at the door and boot cylinder locks, is there a simple way, or does the entire inside of the door panel have to be removed etc. Mostly interested in the door lock key cylinder.
The ignition had already been removed, so I have the code for it. Also does the glove box have its own key or does it share it with the boot?
I guess I should ask if the ignition key is the same as the door key, if so I would not have to take anything apart on the door?!?
Old Jun 25, 2024 | 09:34 AM
  #65
hueyhoolihan's Avatar
my '67 mk2 needs two keys. one for the ignition and a different one for the glovebox. i know that for sure....i dont't know if the barrels are original or not. the head of the ignition key is a wide rectangle, but the one for the glovebox is circular.
one of those keys also opens the door locks (the ignition key i think) and the other one opens the trunk lock. i know that for sure too! i keep the trunk lid unlocked and the glove box key in the glovebox at all times because its door won't stay closed when unlocked.
Old Jun 25, 2024 | 12:13 PM
  #66
JimmyKat's Avatar
Thanks for the information. Please note that I should have reread the info above from Cass3958, as it is clearly explained, before requesting help.
Thanks again
Jimmy
Old Jun 25, 2024 | 01:45 PM
  #67
Jimmy
Yes same keys as S Type. i.e. FS
Original Keys & Fob delivered with my car in my signature.
Old Jun 25, 2024 | 02:32 PM
  #68
Refresh page for all pictures.
Old Jun 26, 2024 | 12:05 PM
  #69
Improved contrast.
Old Jun 27, 2024 | 03:05 PM
  #70
420 & S Type Keys ~ see above.
https://www.jaguarforums.com/forum/m...-276828/page4/
Old Jun 27, 2024 | 05:48 PM
  #71
jerry_hoback's Avatar
I would point out also that mine have the key code stamped into the face of the ignition cylinder so that it is visible from the driver seat. I cant say if they are original to the cars.
Old Jun 28, 2024 | 03:09 PM
  #72
Not original. Face is a polished stainless plate with key slot.
Thermo
US Mid Atlantic
Jul 18, 2023 08:33 AM
VeloceNoto
XK120 XK140 XK150
Jun 18, 2023 03:19 AM
yzteee
Nov 23, 2021 08:29 PM
Hashim_B
Jan 26, 2021 09:12 AM
