Jaguar mark 2 beading clips
Old Aug 10, 2021 | 09:15 AM
Cass3958's Avatar
Not the best picture but if it chromed I think I am right in saying that you should have two and on the S type they fit on the "B" pillar to bridge the gap between the front door handle and rear door chromes strip. You should also have a small plastic rivet/grommet that you put in the hole then the leg of this chrome piece fits into the plastic rivet/grommet.
Old Aug 10, 2021 | 01:52 PM
Glyn M Ruck's Avatar
Originally Posted by Alex4wwl
Hi Glyn, What is this used for? Thanks, Alex
They hold on the two chrome strips on either side of the rear number plate box with a clip that pushes onto their shaft.
The B pillar chrome is held on by a nut.
Old Aug 10, 2021 | 01:56 PM
Coventry Foundation's Avatar
Glyn is right except in the case of a MK2 it is one chrome surround, Also the kit uses 'speed nuts' we think--same effect.
Old Aug 10, 2021 | 02:20 PM
Sorry. Forgot we were talking a Mk2. Number plate box surround.
Old Aug 11, 2021 | 09:40 AM
Alex4wwl's Avatar
Hi Glyn,
Thanks for all your help, much appreciated,
2 last questions,
what does the center beading clips for the bonnet look like?
There are 2 holes in front or the front door- to bonnet and 2 holes behind the rear doors, do they take the pop rivet type clip as well?
Regards,
Alex
Old Aug 11, 2021 | 12:50 PM
Front of front doors & front of bonnet short strip ~ to stop chrome blowing off at speed.
Each use 1 of these held on by nut & anti-shake washer.
Then leaper & then rest of bonnet these horrible things riveted on (you can try the pop rivet clip. I thought they were too small but check) . Some kits have a staple similar to side of bonnet. Aftermarket sell those fancy chrome jobs with a nut.
Two holes behind back doors take these friction bushes to push on chrome spears. Spear studs are now threaded but go into a blind panel so you can't attach nuts. Real dumb!
Old Aug 19, 2021 | 06:27 AM
Alex4wwl's Avatar
Hi Glyn,
The long bonnet side strips, do the tangs bend inwards or outwards?
Regards,
Alex
Old Aug 19, 2021 | 07:40 AM
  #28
Inwards! Toward one another. Leaves a small gap in the middle. Exactly like a paper staple.
I'm blowing this little piece of a larger photo up so much I doubt you can see. It is falling apart. Insufficient resolution/depth of field.
Old Aug 19, 2021 | 09:50 AM
BTW ~ I keep forgetting you have a Mk2 & not an S Type. Ignore friction bushes & spears comment above. Only applies to S Type/420. The Mk2 rear chrome follows the fender line. Does not stop in a spear.
In research this is another type of centre bonnet/hood clip that Jaguar also used on the centre trim of some Mk2's
Gobbers
Apr 7, 2021 03:32 AM
Northern Chris
21
Dec 13, 2020 06:49 PM
meirion1
Aug 19, 2019 07:40 PM
paintbysimon
Sep 8, 2016 01:31 PM
chazaroo
Feb 9, 2013 09:52 AM
